Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
InterFoam- mixing two fluids
Old   July 15, 2022, 06:30
Default InterFoam- mixing two fluids
Jasrin
Jasrin is on a distinguished road
Hello everyone
I want to simulate mixing in a digester using interFoam solver with two incompressible liquids.
The geometry consists of an egg-shaped digester with a draft tube at the center of it (which contains a propeller inside) and an outflow and inflow pipe.
I have to simulate as the digester is filled with one fluid (sludge) and the second fluid (water) enters through the inflow pipe into the digester and mix. Furthermore, I have added one extra input of speed from the draft tube (to simulate the effect of the propeller).
I’m using SetfieldDict to say that the egg is filled with sludge.
The simulation ends after 0.004. I think I’m doing some mistakes when setting the boundary conditions and the SetfieldDicts.
I have attached all the cases, the screenshot of my conceptual model, and the geometry.
I have run this simulation with one fluid using simpleFoam and it worked properly.
I’m new to this and this is part of my master thesis. Can someone guide me a bit?
[URL="https://drive.google.com/file/d/1ujpZjrJ62tJ6Ikezy7qwe8JiF8uTFx6j/view?usp=sharing"]
Jasrin is offline   Reply With Quote
Old   July 15, 2022, 06:39
Lightbulb Try using interMixingFoam
Ahsan
mahsankhan is on a distinguished road
Hello Jasrin,
I think for this purpose, you should use interMixingFoam, which is more appropriate for your case.
Since you are using only two incompressible fluids, you can set air as 0 in your whole domain, since interMixingFoam works with two mixing fluids and air.
I hope this helps!
Have a good day!
Ahsan
mahsankhan is offline   Reply With Quote
Old   July 15, 2022, 07:37
Jasrin
Hello Ahsan,
Thank you for your suggestion.
Have a nice day!
Jasrin
two mixing compresible fluids solver ziemowitzima OpenFOAM Running, Solving & CFD 27 August 13, 2020 13:40
Mixing of two fluids (mashed potato and pigment-colour), singlephase or multiphase Zeljko CFX 7 February 23, 2018 08:58
Mixing 2 fluids paul115 Fluent Multiphase 1 May 18, 2015 16:59
FIDAP-Properties Definition in Fluids Mixing Area Q. Hao FLUENT 0 February 17, 2005 13:00
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 17:15
