Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Using forceCoeffs with multiphaseEulerFoam
Old   August 9, 2022, 11:38
Default Using forceCoeffs with multiphaseEulerFoam
Lennart
levoCFD is on a distinguished road
Hi everyone,
I am working on a multiphase simulation with multiphaseEulerFoam and I would like to use OpenFOAM's post-processing function forceCoeffs.
I am calling it in the controlDict like:
forceCoeffs
        type forceCoeffs;
        functionObjectLibs ("libforces.so");
        patches (walls);
        rhoInf 1.225;
        CofR (0.25 0 0);
        liftDir (0 1 0);
        dragDir (1 0 0);
        pitchAxis (0 0 1);
        magUInf 10.0;
        lRef 1;
         Aref 0.01;
         rho rhoInf;
        U U.gas;
I am getting the following error message:
--> FOAM FATAL ERROR:
No valid model for viscous stress calculation
I checked the source code to find out where the error is generated (l. 277 in functionObjects/forces/forces/forces.C). To avoid the error I have tried adding a transportProperties file with the following content:
transportModel  Newtonian;
rho             [1 -3 0 0 0 0 0] 1;
nu              [0 2 -1 0 0 0 0] 1e-05;
However, this did not solve the issue. Has anyone successfully used forceCoeffs in combination with multiphaseEulerFoam or could give me a hint on how to make them work together?
levoCFD is offline   Reply With Quote
Unknown function type forces and forceCoeffs richard.chung.jones OpenFOAM Post-Processing 2 June 21, 2022 09:53
Difference between forceCoeffs function and Paraview force calculation alexey_sw OpenFOAM Post-Processing 2 June 9, 2021 05:05
Adding forcecoeffs file to the controldict is causing pimpleDyMfoam to crash. pruthvi1991 OpenFOAM Running, Solving & CFD 13 April 13, 2015 02:46
RNG diverged during the analysis the flow over a multi element airfoil, why? s.m OpenFOAM Running, Solving & CFD 0 August 5, 2013 09:39
Problem in forceCoeffs file srini_esi OpenFOAM 0 October 19, 2012 07:34
