Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to display lagrangian particles on a slice?
Old   August 21, 2022, 15:52
Default How to display lagrangian particles on a slice?
Huan Zhang
Jasper Z is on a distinguished road
Dear all,
I have particles in a 3d column, but I want to display the particles at a slice (e.g., center-plane), how can I do it in ParaView? Any suggestions? Thanks!
Jasper
Jasper Z is offline   Reply With Quote
Old   August 21, 2022, 21:52
Huan Zhang
Is there any suggestions? Very appreciate!
Old   September 7, 2022, 05:53
atul1018 is on a distinguished road
Hello
I am also looking for solutions to get 2-D packing at severals planes in 3D packing. here is my post:
Plotting small particle fraction profiles along depth in 3D packing
as you see i tried with clip filter but it doesnt produce 2-d planes cutting packing across specified plane. May be in your case it is useful. Let me know if you find another solution to visualize it.
Best Regards
Atul Jaiswal
atul1018 is offline   Reply With Quote
Old   September 8, 2022, 02:54
Josh Williams
joshwilliams is on a distinguished road
To do this in paraview, you would need to create a small box maybe around 1-2% of the axis length (using `clip' tool), because if you take a slice, very few particles will be exactly on the slice. Then you can use `glyph' to visualise them.
Alternatively, I have used Python for this
from glob import glob
import vedo as v
import matplotlib.pyplot as plt
import numpy as np
def get_slices(pos, axis_to_slice=2, z_coord=3.0, thickness_pct=1):
  pos (np.ndarray) : particle positions
  axis_to_slice (int, 0,1 or 2) : which axis to be normal to cross section
  z_coord (float) : z-location to take slice at
  thickness_pct (float) : thickness of slice to take cross section at
  cut_larger_than_slice = pos[:, 2]>z_coord*(1+thickness_pct/100)
  cut_less_than_slice = pos[:, 2]<z_coord*(1-thickness_pct/100)
  del_inds = np.where(cut_less_than_slice | cut_larger_than_slice)
  pos = np.delete(pos, del_inds, axis=0)
  return pos
# find and read VTK object
fname = glob("VTK/lagrangian/kinematicCloud/kinematicCloud_*.vtk")
assert len(fname) >=1, "no vtk files found"
particles = v.load(fname[0])
marker_size = 2
z_coord = 1 # location that you want to take cross section at
pos = particles.points()
pos = get_slices(pos, z_coord=z_coord)
del particles
print("particles in slice", pos.shape[0])
xsize = 8.0 / 2.54
fig, ax = plt.subplots(1,1, figsize=(xsize, xsize))
ax.scatter(pos[:, 0], pos[:, 1], s=marker_size, c="black", marker='o', facecolors='black',)
ax.axis('off')
ax.autoscale_view('tight')
# fig.tight_layout()
plt.show()
# plt.savefig('image.png', bbox_inches='tight',pad_inches = 0, dpi=400)
joshwilliams is offline   Reply With Quote
Old   September 8, 2022, 05:40
Hi Josh
It would be great if you cpuld share your .VTK file on which I can test the python code. I am not familiar with python and it difficlut to follow without example.
I have sent you my private email address via private message here.
Best Regards
Atul
Old   September 8, 2022, 05:56
Josh Williams
Hi Atul,
You can generate data for this by running the MPPICFoam tutorial "injectionChannel" (available in OpenFOAM 6).
To generate VTK file for LIGGGHTS, you can use LPP (link). If you are not familiar with python, maybe easier to go with the "box" clipping approach I mentioned in Paraview.
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 07:21
Radiation heating of lagrangian particles in reactingParcelFoam CHUIKOV OpenFOAM Running, Solving & CFD 0 February 28, 2021 14:53
Corellation dimension of lagrangian particles oswald OpenFOAM Post-Processing 0 January 27, 2016 07:30
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 03:10
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
