Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Post Processing Cutting Planes
Old   September 16, 2022, 16:52
Default Post Processing Cutting Planes
Pamela93 is on a distinguished road
Hello, I am doing the postprocessing of my data and I want to get the velocity, pressure, and the water level in my cross, for this purpose I defined the attached code, however, after running the command "postProcess -func surfaces" or "interFoam -postProcess -func surfaces" no folders neither VKT file format are created. The code is running; however, I do not know where is saving the files. If someone could help, I would be grateful, maybe it is something wrong in the code, and I did not notice.
Thank you in advance
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Version:  v2012
    \\  /    A nd           | Website:  www.openfoam.com
     \\/     M anipulation  |
Description
    Writes out surface files with interpolated field data in VTK format, e.g.
    cutting planes, iso-surfaces and patch boundary surfaces.
    This file includes a selection of example surfaces, each of which the user
    should configure and/or remove.
//#includeEtc "caseDicts/postProcessing/visualization/surfaces.cfg"
surfaces
	type            surfaces;
	libs            ("libsampling.so");
	writeControl    writeTime;
	surfaceFormat   vtk;
	interpolationScheme cellPoint;
	fields
			p
			U
			alpha.water
	x (1 0 0);
	y (0 1 0);
	z (0 0 1);
	origin (0 0 0);
	cuttingPlane
		type         cuttingPlane;
		planeType    pointAndNormal;
		pointAndNormalDict
			basePoint    (15.992500305175781 9.192850112915039 3.3970142900943756);//$origin;
			normalVector $x;
		interpolate  true;
	isosurface
		type            isoSurfaceCell;
		interpolate     true;
	patchSurface
		type        patch;
		interpolate true;
Pamela93 is offline   Reply With Quote
post processing for CEL expressions Niru CFX 0 May 10, 2013 14:13
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 07:21
[OpenFOAM] is parallel processing available in parafoam for post processing? sachinlb ParaView 1 August 14, 2012 10:52
post processing in CFX11.0 u k jha CFX 1 September 17, 2010 06:53
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
