-   OpenFOAM Post-Processing (https://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   0 wallHeatFlux on External Patch (https://www.cfd-online.com/Forums/openfoam-post-processing/247000-0-wallheatflux-external-patch.html)
amber25 January 7, 2023 12:30
2 Attachment(s)
I am using OpenFOAM-10 with chtMultiRegionFoam on a heat transfer problem with only solids.
The geometry of the model is given below:
Attachment 92915
I use fixed boundary conditions where T = 373 [K] on the outside edges of the model. This gives the result provided in the figure in the image below:
Attachment 92916
However, when I try to extract the heat flux at the outside edges of the model in the "system/controlDict" file using:
    wallHeatFlux1
        type wallHeatFlux;
        libs ("libfieldFunctionObjects.so");
        region Cool;
        executeControl writeTime;
        executeInterval 1;
        writeControl writeTime;
        writeInterval 1;
In "4e+10/Cool/wallHeatFlux", I simply get
    Sides
        type            calculated;
        value          uniform 0;
This is only the output for the patch on the outside edges of the model that I have labeled "Sides".
Does anyone know why this is the case? The heat flux is calculated properly on all internal surfaces and reported in "4e+10/Cool/wallHeatFlux" but is not of interest.
