Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
reconstructPar error
Old   June 9, 2023, 23:04
Post reconstructPar error
Jerry L.D. Cheng is on a distinguished road
Hello everyone,
I am getting an error when using OpenFOAM-v2106 reconstructPar, it seem like there are some problem when access memory.
Does anyone now how to handle this error? any help will be much appreciated.
Follwing is the output message :
Create time
Reconstructing fields
region=region0
Time = 0.0005
Reconstructing FV fields
    Reconstructing volScalarFields
        p
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2  ? in /lib64/libpthread.so.0
#3  ? at ??:?
#4  ? at ??:?
#5  ? at ??:?
#6  ? at ??:?
#7  __libc_start_main in /lib64/libc.so.6
#8  ? at ??:?
[node044:53850:0:53850] Caught signal 11 (Segmentation fault: tkill(2) or tgkill(2) at address 0x116f0000d25a)
==== backtrace (tid:  53850) ====
 0 0x0000000000012ce0 __funlockfile()  :0
 1 0x0000000000012b7f gsignal()  :0
 2 0x0000000000012ce0 __funlockfile()  :0
 3 0x0000000000551f19 Foam::fvFieldReconstructor::reconstructFvVolumeField<double>()  ???:0
 4 0x0000000000553474 Foam::fvFieldReconstructor::reconstructFvVolumeField<double>()  ???:0
 5 0x0000000000553741 Foam::fvFieldReconstructor::reconstructFvVolumeFields<double>()  ???:0
 6 0x000000000046fc8a main()  ???:0
 7 0x000000000003aca3 __libc_start_main()  ???:0
 8 0x000000000047285e _start()  ???:0
Segmentation fault (core dumped)
Jerry L.D. Cheng is offline   Reply With Quote
Old   June 15, 2023, 04:33
Vinzenz Götz
Vinzmann is on a distinguished road
Hi Jerry,
what options do you use when starting reconstructPar?
Can you give some further details on your case?
Best regards,
Vinz
Vinzmann is offline   Reply With Quote
openfoam;reconstructpar
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
