Error when getting kappaEff from turbulenceFields
1 Attachment(s)
I am trying to get the kappaEff field from my channel flow simulation on OpenFOAM 11 (I attach the case) by using the turbulenceFields function object: Code:
foamPostProcess -latestTime -solver fluid However I get the next error: Code:
--> FOAM FATAL ERROR: As far as I see in the code, at the execute function there is an if statement in function of the use of a fluidThermophysicaltransportModel, which I use (eddyDiffusivity model). However I cannot reach that code block (where kappaEff is processed) but the next one, that only requires a compressible momentum turbulence model. Have you ever tried to get kappaEff from this functionObject? Am I missing something in my dictionary or there is a bug? Regards Agustín |
