Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Pass functionObjects results to other functionObjects
Old   August 7, 2024, 05:29
Default Pass functionObjects results to other functionObjects
Alczem is on a distinguished road
Hey!
I would like to use the outputs of two functionObjects in a third functionObjects.
More precisely, I would like to divide the areaAverage of a field on a patch by the max value of the same field on another patch. Supposedly, surfaceFieldValue stores results to be reused in the next postprocessing functions, but it seems to be the case only for specific functions.
I cannot use coded functions (precompiled OpenFoam on Windows) or any kind of dynamic code. So far, I have tried:
  • exprFields to compute this value, but it does not recognize the previous FOs or the max or average mathematical functions
  • add or multiply work to add fields, but not functionObjects outputs
  • several variants of these tools
Does anyone know a way to further process functionObjects results? Thanks!
Alczem is offline   Reply With Quote
Old   November 26, 2024, 11:28
Giorgio
giorgianig is on a distinguished road
I stumbled on this post because I have exactly the same need. Did you menage to solve the issue?
giorgianig is offline   Reply With Quote
Old   November 27, 2024, 05:21
Hey!
Sadly I have not found a solution. I managed to find a way by using Paraview for my specific case, but I could not generalize to other cases.
Old   November 28, 2024, 08:39
Domenico Lahaye
dlahaye is on a distinguished road
can you instruct the first function object to store data in the object registry and the second to rad from the object registry?
dlahaye is online now   Reply With Quote
Old   November 29, 2024, 05:02
I tried to use the stored results but could not make it work. Is there a functionObject that allows to force the reading of other FOs' results? Thanks for the hint!
Old   November 29, 2024, 05:06
Domenico Lahaye
What exactly did you try?
What error message do you obtain?
Thx, D.
Old   November 29, 2024, 05:09
Giorgio
Thx, D.
Here is what I tried.
I wrote a first function object:
HTML Code:
cuttingPlane001
    type            surfaceFieldValue;
    libs            (fieldFunctionObjects);
    enabled         yes;
    writeControl    timeStep;
    writeInterval   1;
    writeFields     no;
    writeToFile     no;
    //interpolationScheme cellPoint;
    regionType      sampledSurface;
    name            z-0.01;
    sampledSurfaceDict
            type                    cuttingPlane;
            planeType               pointAndNormal;
            pointAndNormalDict
                    basePoint       (0 0 0.01);
                    normalVector    (0 0 1);
            source cells; // sample cells or boundaryFaces
            interpolate true;
    operation       areaAverage;
    fields          ( alpha.SA );
    result ctp001;
and another to use the result cpt001
HTML Code:
expr001
	type exprField;
	name expr001;
	expression "(0.9-ctp001)/0.4";
	dimensions      [   ];
I am calling them in controlDict
HTML Code:
functions
    #include "cuttingPlane001"
    #include "expr001"
but I get:
HTML Code:
--> FOAM FATAL IO ERROR: (openfoam-2312 patch=240220)
Entry 'field' not found in dictionary
"/home/giorgio/tutorials/combustion/reactingFoam/RAS/TEST_liquid/lockExchange/system/controlDict/functions/expr001"
file: system/controlDict/functions/expr001 at line 10 to 14.
Old   November 29, 2024, 07:31
Domenico Lahaye
One example of a function object storing data in the object registry is at Register object inside functionObject without static pointer
Time sensitivity analysis - results variation qntldoql FLUENT 1 January 25, 2022 01:07
My results become inconsistent when using PIMPLE (nOuterCorrectors>1) instead of PISO FloB OpenFOAM Running, Solving & CFD 5 May 17, 2021 07:17
Validating the results of numerical modeling compared to the results of another model ENG.AHMAD FLUENT 0 June 22, 2020 17:49
bad heat transfer results with low y+ me45 OpenFOAM Running, Solving & CFD 0 April 29, 2020 12:56
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
