Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating the Convective Heat Transfer Coefficient for incompressible fluide
Old   August 26, 2024, 10:41
Default Calculating the Convective Heat Transfer Coefficient for incompressible fluide
Fadi M. Bourarach
fmbourarach is on a distinguished road
Hello Foamer,
I am relatively new to openfoam.
I want to extract the convective heat transfer coefficient (CHTC) and I am facing some issues.
This is my setup:
- Geometry : searchableRotatedBox (named panel)
- Solver : buoyantBoussinesqSimpleFoam
- Meshing : SnappyHexMesh (with layers and refinement regions)
- fluide : Incompressible
- RAS : kOmegaSST
- transportModel : Newtonian
1. direct : using "heatTransferCoeff":
heatTransferCoeff1
    // Mandatory entries (unmodifiable)
    type            heatTransferCoeff;
    libs            (fieldFunctionObjects);
    // heatTransferCoeff;
    // Nu    : Nusselt number
    // L     : Characteristic length that defines the scale of the physical system
    // kappa : Thermal conductivity of the fluid
    field           chtc_0;
    patches         (panel);
    htcModel        ReynoldsAnalogy; // options: ReynoldsAnalogy; localReferenceTemperature; fixedReferenceTemperature
    UInf            (20 0 0);
    Cp              CpInf;
    CpInf           1000;
    rho             rhoInf;
    rhoInf          1.2;
    // Optional (inherited) entries
    result          chtc_0;
    region          region0;
    enabled         true;
    log             true;
    timeStart       0;
    timeEnd         5000;
    executeControl  timeStep;
    executeInterval 1;
    writeControl    timeStep;
    writeInterval   1;
The error I get:
--> FOAM FATAL ERROR:
Unable to find a valid thermo model to evaluate q
2. Indirect : wallHeatFlux
wallHeatFlux1
    type            wallHeatFlux;
    // Optional entries (runtime modifiable)
    patches     (panel);
    qr          qr;
The error I get:
Unable to find compressible turbulence model in the database
Apparently I can't use it for incompressible flow (wallHeatFlux utility for an incompressible case)
Can you help me please ?
Thank you for you time !
Cheers,
Fadi
fmbourarach is offline   Reply With Quote
Calculating local heat transfer coefficient for Cylindrical fins karyan07 FLUENT 0 April 29, 2021 00:47
Convective heat transfer coefficient huizju OpenFOAM Running, Solving & CFD 0 July 7, 2020 08:25
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Conjugate Heat Transfer & calculating force coefficient nazli OpenFOAM Running, Solving & CFD 0 July 21, 2017 06:07
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
