Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Coded function object- strainRate
Old   December 5, 2024, 12:46
Default Coded function object- strainRate
GaspA
GaspA is on a distinguished road
I am trying to calculate the strain rate during the calculation and write it as an ASCII file in the temps folder.
My idea is simply to write the sqrt(2.0)*mag(symm(grad(U))) function in a functionObjects in system/controlDict.
I am using OpenFoam 11.
I took as a basis the example provided with the openfoam.org documentation.
https://cpp.openfoam.org/v11/classFo...ionObject.html
And it works...... No surprises
writeMagU
libs ("libutilityFunctionObjects.so");
type coded;
codeWrite
// Lookup U
const volVectorField& U = mesh().lookupObject<volVectorField>("U");
// Write
mag(U)().write();
When I try to replace the formula entered, using for example grad(U) or fvc::grad(U) it does not work. Compilation errror "error: ‘fvc’ has not been declared"
What is surprising is that by replacing "codeWrite" with "code", the compilation works but it is impossible to write the file.
Can someone tell me how to integrate the formula sqrt(2.0)*mag(symm(grad(U))) into such a function?
Thank you.
GaspA
GaspA is offline   Reply With Quote
../externals/cgns/hdf5/H5public.h:63:10: fatal error: mpi.h: No such file or director Mohsin1 SU2 8 November 25, 2023 04:46
interFoam and scalarTransport function object with fvOptions sources fusij OpenFOAM Running, Solving & CFD 4 April 18, 2022 08:12
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
