Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to get boundary values using graph post-process function?
Like Tree2Likes
  • 1 Post By Tobermory
  • 1 Post By thiagopl
Old   January 16, 2025, 17:17
Default How to get boundary values using graph post-process function?
Thiago Parente Lima
thiagopl is on a distinguished road
Hi all,
To exemplify my question I will use a 1D steady state conduction case, presented here in section "1.1 Part A: Steady-State conduction" (case attached in OF 12).
What I want is to plot the temperature, T, along x axis from one boundary to the other (y and z position doesn't matter here). Using the graphCell post-processing function, I get the exact cell center values inside the domain. But, I want also to get the values on the boundaries, i.e., T at x=0 m and x=0.2 m. For this, I thought I should use graphCellFace function which says: "One graph point is generated on each face and in each cell that the line intersects.".
However, using the following configuration for graphCellFace, I can't get the correct values for the temperature at the boundaries, as shown bellow.
start           (0.0 0.5 0.005);
end             (0.2 0.5 0.005);
fields          (T);
axis            x; // The independent variable of the graph. Can be "x",
                          // "y", "z", "xyz" (all coordinates written out), or
                          // "distance" (from the start point).
#includeEtc "caseDicts/functions/graphs/graphCellFace.cfg"
#           x             T
            0       390.535
        0.005         390.5
         0.01           388
        0.015         385.5
         0.02           383
        0.025         380.5
intermediate values ommited for simplicity...
        0.175         305.5
         0.18           303
        0.185         300.5
         0.19           298
        0.195         295.5
          0.2       295.465
I should expect 393 K at x=0 m and 293 K at x=0.2 m, so it seems that some interpolation is happen on the boundaries. Using graphUniform or graphFace doesn't help either.
The question is, how to get the correct values on the boundaries?
P.S.: I don't want to use paraview.
Field of interest: heat transer. OpenFOAM Foundation's distribution user.
thiagopl is offline   Reply With Quote
Old   January 28, 2025, 10:10
Tobermory will become famous soon enough
You need to adjust the interpolationScheme from cellPoint to cellPointFace, and the line type from lineCell to lineFace.
You had already pretty much done the second of these by including graphCellFace.cfg, but this also includes graph.cfg which sets interpolationScheme to cellPoint.
I understand OF's use of include files, but sometimes its just easier to have all the parameters visible and in one file, eg:
type            sets;
libs            ("libsampling.so");
writeControl    writeTime;
start           (-0.1 0.5 0.005);
fields          (T);
axis            x;
//interpolationScheme cellPoint;
interpolationScheme cellPointFace;
setFormat       raw;
sets
    line
        //type            lineCell;
        type            lineFace;
        axis            $axis;
        start           $start;
        end             $end;
Finally, note that I set the start to outside the domain, since otherwise for some reason (rounding error?) it was missing the data point at x=0. Output is now:
#           x             T
            0           393
         0.01           388
         0.02           383
         0.16           313
         0.17           308
         0.18           303
         0.19           298
thiagopl likes this.
Tobermory is offline   Reply With Quote
Old   January 29, 2025, 07:52
Thiago Parente Lima
Hi Tobermory,
Thank you for the answer. You are right. I think this should be corrected since when we choose for graphCellFace we want this face values at boundaries. In a more complex case this error could result in many problems, for example, when trying to validate results near walls.
Here is a corrected version of the graphCellFace, still using the include files.
start           (-1e-6 0.5 0.005);	//setting the start point a bit before 0.0
end             (0.200001 0.5 0.005);	//setting the end point a bit after 0.2
fields          (T);
interpolationScheme cellPointFace; //this line MUST be after the #includeEtc command
The result:
#           x             T
            0           393
        0.001         392.5
        0.002           392
        0.003         391.5
        0.197         294.5
        0.198           294
        0.199         293.5
          0.2           293
Tobermory likes this.
../externals/cgns/hdf5/H5public.h:63:10: fatal error: mpi.h: No such file or director Mohsin1 SU2 8 November 25, 2023 04:46
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
