Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
stream functions calculation
Old   March 22, 2025, 02:49
Default stream functions calculation
A. Min
alimea is on a distinguished road
Hi guys
I used the rheoFoam solver to solve the flow on a square cylinder and then calculated the stream functions using
postProcess -func streamFunction
However, the results are wrong as you can see:
So, I plotted only sai =0 streamline. As you can see in the picture the streamline sai = 0 is not straight! it came from the inlet patch and meets the cylinder surface on a vertex on of square! Then it goes around the cylinder and leaves the cylinder on the other vertex!
Actually, I don't know how to solve this problem!
Note: I checked this tool to find the stream function of flow over a circular cylinder.
alimea is offline   Reply With Quote
cylinder flow, openfoam, streamline
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Stream Functions in InterFOAM kalaikdr OpenFOAM Post-Processing 3 June 6, 2014 04:18
Stream is sticking to the wall pawel123 FLUENT 0 October 18, 2013 07:38
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 10:16
