Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Pushed to ParaView but options are not present
Old   May 14, 2025, 00:50
Unhappy Pushed to ParaView but options are not present
Ayush Tokeria
atokeria is on a distinguished road
When I touch a .foam file it creates exactly what I expect except for that the file does not contain the U, T, p, p_rgh... variables. However, my timestep that has been written does have them in the files. Does anyone know why my .foam file does not contain this? The part I am talking about is in ParaView, under the solid colour dropdown where it is expected that there will be all of these different options present.
atokeria is offline   Reply With Quote
Old   May 14, 2025, 05:50
Yann
Yann will become famous soon enoughYann will become famous soon enough
The .foam file is an empty file used to trigger the OpenFOAM reader in ParaView. It directly reads the OpenFOAM files and directories, so if your files exist in your case, ParaView should be able to read it.
Few things to verify in ParaView:
  • If you ran your case in parallel and your data is saved in processor directories, switch the case type to "decomposed case". If not, leave it on "Reconstructed case"
  • tick or untick "Skip zero time" depending on what you want to do (loading the 0 timestep or skipping it to load only the timesteps written by the solver during the run)
Don't forget to click on "Apply" to load the data.
Then make sure to move to the proper timestep:
And you can also check the "Cell arrays" list to verify that you see your variable list there.
Yann is offline   Reply With Quote
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) Milan2013 OpenFOAM Installation 23 April 20, 2017 05:49
[cfMesh] workflowControls options result in that Paraview cannot open rnburne OpenFOAM Community Contributions 2 June 8, 2016 08:22
[OpenFOAM] No eye icon when using ParaView with OpenFOAM rmvega ParaView 0 July 2, 2014 09:59
[General] Paraview nice animation PyGloo ParaView 4 June 7, 2012 12:34
Paraview 3.12 - How to compile with ffmpeg for animation tunkers OpenFOAM Installation 6 January 21, 2012 21:08
