Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Expressions inside functionobjects
Old   October 17, 2025, 04:42
Default Expressions inside functionobjects
Andy
Starcatcher is on a distinguished road
Hi folks,
I am using the OF2412 and I ouwld like tp write out special postprocessing logs for which there are not prepared function objects. For example when simulationg with pimpleFoam the Head at the outlet of a pump would be calculated as:
(p+U^2/2)/9.81
Online, I did find some hints, that functionObjects such as "type surfaceFieldValue" can process expressions, but no full information, which would guide me.
Maybe someone can provide an example of such a function object.
Otherwise I have to conitue using "type coded;" function object which is not very handy.
Thank you
Starcatcher is offline   Reply With Quote
Old   October 17, 2025, 06:21
Yann
Yann will become famous soon enoughYann will become famous soon enough
The exprField function object should do the job!
https://doc.openfoam.com/2312/tools/...eld/exprField/
Cheers,
Yann
Yann is offline   Reply With Quote
Difference Between UDF and Expressions in Thermal Comfort Evaluation? danisnug FLUENT 7 April 11, 2023 05:59
[snappyHexMesh] snappyHexMesh not deleting the inside cells Bdew8556 OpenFOAM Meshing & Mesh Conversion 9 May 14, 2019 11:53
regarding simulation of heat and mass transfer inside thermosyphon 1757003@kiit.ac.in ANSYS 1 May 14, 2019 03:06
[snappyHexMesh] Inside and outside mesh with snappyhexmesh nzy102 OpenFOAM Meshing & Mesh Conversion 21 February 16, 2016 17:42
How to determine a point is inside a tetrahedral? G.P. Xia Main CFD Forum 16 January 12, 2000 12:15
