Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
plot a difference value each iteration
Old   November 14, 2025, 07:04
Default plot a difference value each iteration
elia_l is on a distinguished road
Hi guys,
I have an issue regarding the real time plot of static pressure rise across the fan I'm running. I explain.
I already got average static pressure on inlet and outlet patches by use of:
patchAverage_inlet_inletdom
type surfaceFieldValue;
libs ("libfieldFunctionObjects.so");
writeControl timeStep;
writeInterval 1;
patch inlet_inletdom;
select patch;
fields (p);
operation areaAverage;
writeFields false;
log true;
patchAverage_outlet_outletdom
writeInterval 1;
patch outlet_outletdom;
select patch;
fields (p);
writeFields false;
log true;
At this point two .dat files are created inside postProcessing/ folder and I can plot them by use of gnuplot, using the following script:
gnuplot -persist <<EOF2 &
set title "Static Pressure"
set xlabel "Iterations"
set ylabel "Static pressure [Pag]"
set grid
do for [i=1:100000] {
plot \
"postProcessing/patchAverage_inlet_inletdom/0/surfaceFieldValue.dat" using 1:2 with lines title "psin", \
"postProcessing/patchAverage_outlet_outletdom/0/surfaceFieldValue.dat" using 1:2 with lines title "psout"
pause 1
EOF2
My question is: how can I calculate inside OF (I’m using OpenFOAM 13 Foundation) the difference of previous two average values, write it inside a .dat file and plot it using gnuplot inside the same plot of psin and psout?
Thanks in advance.
elia
elia_l is offline   Reply With Quote
Old   November 14, 2025, 13:21
Michael Häckel
michael_h is on a distinguished road
You can use the ddt postprocessing function to calculate the time derivative of the pressure field. Then you can calculate the average of the derivative. The result is not exactly the same as with your proposed calculation method, but almost.
https://doc.cfd.direct/openfoam/user...-functionality
There is no documentation but the usage is like for most other postprocessing functions.
Instead of your gnuplot script you can also use foamMonitor. That is a bit more comfortable.
michael_h is offline   Reply With Quote
Old   November 17, 2025, 15:22
Thank you michael for the reply. Finally I solved the issue in this way:
dps
type fieldValueDelta;
operation subtract;
writeInterval 1;
log true;
region1
#includeEtc "caseDicts/functions/surfaceFieldValue/surfaceValue.cfg"
fields (static(p));
region2
fields (static(p));
dfr
operation add;
writeInterval 1;
log true;
region1
operation sum;
fields (phi);
region2
operation sum;
fields (phi);
tolerance in solver VS tolerance in residualControl FluidKo OpenFOAM Running, Solving & CFD 13 January 30, 2024 11:59
pimpleFoam residual increase in final iteration AhmedHafez OpenFOAM Running, Solving & CFD 0 December 1, 2022 04:03
Change foamLog for Pimple iteration and new variables Magistrane OpenFOAM Post-Processing 1 April 26, 2019 05:26
contour plot: mass flow difference jai CFX 3 December 16, 2017 07:20
difference plot: turbulent kinetic energy (URANS) vs. Reynolds Stresses (LES) fabfi CFX 2 November 21, 2017 11:29
