March 6, 2014, 06:42 |
Function Object cloudInfo
Rep Power: 13 |
if have seen that since OF v2.2.0 a functionality called cloudInfo was implemented. Im very interested in using this tool , but i have no idea of how this is done. Do i have to write a custom pre-processor to use this utility? Help would be appreciated. Thanks in advance. http://www.openfoam.org/version2.2.0...processing.php Regards Mentalo |
March 7, 2014, 03:06 |
Rep Power: 13 |
Ok now I got it running. But there ist still a strange problem. On a singel core, without decomposing the case, the cloudInfo object works perfectly fine. But by starting the run on MPI, I get an error message:
faceSource cuttingplane_average output: areaAverage(sampledSurface) for p = 99991.3 areaAverage(sampledSurface) for U = (7.71105e-05 -6.53393e-06 20.1689) areaAverage(sampledSurface) for T = 280.929 areaAverage(sampledSurface) for rho = 1.23573 areaAverage(sampledSurface) for C7H16 = 5.37203e-98 [philipp-Home:3137] *** An error occurred in MPI_Recv [philipp-Home:3137] *** on communicator MPI_COMM_WORLD [philipp-Home:3137] *** MPI_ERR_TRUNCATE: message truncated [philipp-Home:3137] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 3137 on node philipp-Home exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). I tried to execute the post processing, after reconstructing the case, via execFlowFunctionObjects, but then OpenFoam gets stuck saying: Code:
Time = 0 Reading phi --> FOAM Warning : --> FOAM FATAL IO ERROR: cannot find file file: /home/philipp/cfd/OF_22x/full_spray_SP1_5/0/phi at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. Time = 0.0005 Reading phi Reading U Reading p No finite volume options present Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader chemkinReader Reading CHEMKIN thermo data in new file format |
Display Modes | |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
