Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Something about log file
Like Tree1Likes
  • 1 Post By hjasak
Old   September 13, 2007, 06:37
Default Hi all, I have some questio
Giovanni Boldrini
giovanni is on a distinguished road
Hi all,
I have some questions about the files generated by foamLog. In a rhoTurbFoam case I generated "logs" directory, there I can find some unknown files. So,
1) What's the difference between a name_0 file to a name_1 file?
2) Why there are 3 rho files? (rho_0, rho_1, rho_2)
3) What's the difference between contCumulative, contGlobal and contLocal?
Thanks a lot!
Giovanni
giovanni is offline   Reply With Quote
Old   September 13, 2007, 13:11
Default Transcript from previous discu
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Transcript from previous discussions:
By Eugene de Villiers on Thursday, May 26, 2005 - 03:06 am: Edit Post
U_0 and the other *_0 fields are the old time values (i.e. timestep previous to U). They are necessary to restart calculations that use second order accurate schemes in time like Crank-Nicholson.
By Anja Stretz on Wednesday, January 18, 2006 - 07:36 am: Edit Post
For example:
time step continuity errors :
sum local = 1.05535e-08, global = 1.65393e-14, cumulative = -9.944e-11
What exactly do you mean by converging the pressure more tightly?
Anja
By Hrvoje Jasak on Wednesday, January 18, 2006 - 07:41 am: Edit Post
This does not worry me at all: it says your global continuity error is 1e-14, which is the double precision round-off error, the sum local tells me that in the line above your pressure solver has converged to about 1e-8; in other words, all is well.
Nothing to worry about here.
Hrv
msrinath80 is offline   Reply With Quote
Old   September 13, 2007, 14:01
Default Thank you Srinath! Giovan
Giovanni Boldrini
Thank you Srinath!
Giovanni
Old   September 13, 2007, 15:22
Default The foamLog script filters the
Mattijs Janssens
mattijs is on a distinguished road
The foamLog script filters the provided log file. It just scans for certain patterns and the first occurrence for that becomes '_0', the second '_1' etc. so if your solver solves multiple times for e.g. p in one timestep they are kept separate.
The patterns it uses are defined in the foamLog.db file in the same directory as the foamLog script. If it is missing some feel free to extend it for other solvers/linear solvers and send me a copy.
mattijs is offline   Reply With Quote
Old   September 14, 2007, 02:50
Default Thanks a lot Mattijs for your
Giovanni Boldrini
Thanks a lot Mattijs for your perfect clarification!
I'll see foamLog.db to know better foamLog's behaviour.
Regards
Giovanni
Old   September 28, 2007, 08:53
Default I want to write some global re
Tomislav Sencic
tsencic is on a distinguished road
I want to write some global results in the logSummary file. For example for O2 concentration I write in the code:
<< sum(Y[1]*mesh.V())/sum(mesh.V()) << tab
and I obtain as output
(sum((O2*V))|sum(V)) [0 0 0 0 0 0 0] 0.233233
for each timestep.
How could I get just the value, just 0.233233?
tsencic is offline   Reply With Quote
Old   September 28, 2007, 09:10
Default Easy: << sum(Y*mesh.V())/su
Hrvoje Jasak
Easy:
<< sum(Y[1]*mesh.V())/sum(mesh.V()).value() << tab
Enjoy,
Hrv
Mahmoud_aboukhedr likes this.
Hrvoje Jasak
Old   March 25, 2009, 09:46
Chris
chris_sev is on a distinguished road
Sorry for digging but I have some question regarding to foamLog.
I have written new variable to logSummary. Once the job is finished and I type foamLog, log directory is created but my new variable is not present there.
Should I modify somehow foamLog code to make it possible?
I am using OF 1.5
thanks for reply!
chris
chris_sev is offline   Reply With Quote
Old   March 25, 2009, 14:10
Chris
Ok,I have sorted this by modifying foamLog.db
PLOT3D ASCII solution file to MATLAB data file Sandeep Rana Main CFD Forum 4 June 11, 2010 09:48
[OpenFOAM] ParaView exiting while trying to save image file or movie file 21kalee ParaView 3 January 23, 2008 16:01
Changing gambit file without change of case file?? Asghari FLUENT 2 August 28, 2006 13:48
Covert gambit file to polyflow file John FLUENT 5 August 6, 2004 08:31
Converting a surface file to a volume file Amir FLUENT 2 December 30, 2002 04:53
