April 8, 2008, 05:55 |
Problem with xy plot
Vivien
Rep Power: 17 |
Hi, everyone
I have a problem with x-y plot in paraview. I tired with several tutorials but seems i could not get the velocity profile accross a single line. For example after i run with icofoam and start the paraview,the steps are: 1)select a time instance 2)filter-> append dataset 3)filter->probe Then I select 'line' as a probe object and specify two points. However, only pressure(or maybe only scalar) can be plotted, Ux, Uy, Uz are not appeared in the'point scalars'. Any one has some idears? Thanks in advance! |
April 8, 2008, 07:48 |
Hi Qii,
Maybe, you can have
Cedric DUPRAT
Rep Power: 17 |
Hi Qii,
Maybe, you can have a look in the user guide chapter 7.5: Sampling data for plotting graphs. It is about the sample utility. I think It will be usefull :o) regards, Cedric |
April 9, 2008, 03:14 |
Hi, Cedric,
Thanks for your
Vivien
Rep Power: 17 |
Hi, Cedric,
Thanks for your idea. But does it mean that I did not follow the right steps? Qi |
January 13, 2009, 09:51 |
Hi, I have the same problem, c
Ali Mansouri
Rep Power: 17 |
Hi, I have the same problem, can anybody help ?
only pressure can be plotted in Paraview 2.4, Ux, Uy, Uz are not appeared. |
April 23, 2009, 06:42 |
Philip Cardiff
Rep Power: 34 |
Did you first use 'Ucomponents' to break the velocity into its repective components or use 'magU' to get the magnitude of the velocity? Then Ux, Uy and Uz or magU should appear as they are scalars. Hopefully this helps, Philip C |
April 23, 2009, 06:52 |
Philip Cardiff
Rep Power: 34 |
I am using OpenFOAM v1.4.1
Possibly the commands in OpenFOAM v1.5 are: "foamCalc components U" or "foamCalc mag U" |
Problem diverges when exhaust valve opens | swerner0711 | AVL FIRE | 0 | September 21, 2018 07:14 |
A problem on the Energy spectrum plot by using FFT | Martin duan | OpenFOAM Post-Processing | 5 | February 22, 2016 10:12 |
Problem with Residual plot raising up to hige numbers na do not converge | fardinkhalili | STAR-CCM+ | 4 | March 25, 2014 09:35 |
X-Y plot problem, please help | tobytoby | FLUENT | 8 | March 20, 2013 20:57 |
CFD post vector plot problem | bharath | CFX | 3 | February 8, 2011 17:16 |
