Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
¿center of pressure and moments in interDyMFoam?
Old   March 17, 2010, 12:42
Default ¿center of pressure and moments in interDyMFoam?
angel
anmartin is on a distinguished road
Anybody know if it is possible to calculate the center of pressure and moments in a multiphase simulation using interDyMFoam
Best regards,
anmartin is offline   Reply With Quote
Old   March 17, 2010, 15:16
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Best regards,
Can you tell me what a center of pressure and/or momentum is?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 21, 2010, 07:53
Default forces, momoents about and specified center and center of pressure
angel
I want to obtain the sloshing forces and moments to be compare with experimental data of an tank partially filled with water suspected to a sinusoidal lateral excitation in Y direction [A*cos(w*t)]
In fluent it can be done by “reports>forces>...”
I can calculate the forces by [patchIntegrate p walls] this generate the total forces in X Y Z
[Time=15
Area vector of patch walls[0] =(5,51E-17 -8,75E-17 7,72E-19)
Area magnitude of patch walls[0] = 1,01
Reading volScalarField p
Integral of p over vector area of patch walls[0] = (-86,11 -305,32 3,18)
Integral of p over area magnitude of patch walls[0] = 99687,5
But I don't know the moments about an specified center [in my case a point in the middle of the lower part of the tank, were I fixed it to the shaker using a 3 axle load cell, in order to measure the vertical forece (Fz), lateral force (Fy) and roll moment(Mx)]
If you can help me I will be very gratefully
Best regards,
Old   March 21, 2010, 07:58
sega's Avatar
Sebastian Gatzka
I would try to have a look into the tool, which calculated the forces.
Maybe you will have to alter it, so it will output the values you want.
Ensight: Visualizing forces and moments David EnSight 3 December 19, 2012 13:47
Movie for static pressure chouki FLUENT 2 June 11, 2008 15:53
How to find the coordinates of center of pressure Alexey Siemens 0 February 1, 2007 10:37
Fluent-V5,Turbomachinery (stagnation pressure live its own life) Alberto Tamm Main CFD Forum 19 May 27, 1999 14:42
