Problems while using the sample post-procesing tool
Old   July 3, 2009, 16:41
Default Problems while using the sample post-procesing tool
Sven Schweikert
svens is on a distinguished road
Hello together.
I have got a problem while using the post-processing tool sample.
With my the settings in sampleDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      sampleDict;
interpolationScheme cell;
setFormat     raw;
sets
     pos1
           type     midPoint;
           axis     y;
           start    (   0.00000000000000        0.000000       0.000000     );
           end      (   0.00000000000000       0.1000000       0.000000     );
     pos2
           type     midPoint;
           axis     y;
           start    (  0.408163265306122        0.000000       0.000000     );
           end      (  0.408163265306122       0.1000000       0.000000     );
     pos49
           type     midPoint;
           axis     y;
           start    (   19.5918367346939        0.000000       0.000000     );
           end      (   19.5918367346939       0.1000000       0.000000     );
     pos50
           type     midPoint;
           axis     y;
           start    (   20.0000000000000        0.000000       0.000000     );
           end      (   20.0000000000000       0.1000000       0.000000     );
surfaces
fields
   T
   U
I'm using a geometry with 40 cells in the y-dimension.
Therefore I thought that there have to be 40 output values at every defined sample position.
Sadly I received just 39 values at some certain points – the value of the last (the 40.) cell is missing in that cases.
Has anyone the same problem? How can I fix it? Is there probably a better way to output defined data than the sample tool?
Thanks a lot - svens
svens is offline   Reply With Quote
Old   July 4, 2009, 08:14
xinguang cui
flying is on a distinguished road
Hey!
I wish this could be helpful for you.
http://www.cfd-online.com/Forums/ope...tml#post219114
flying is offline   Reply With Quote
Old   July 4, 2009, 20:49
Sven Schweikert
Hey flying - thanks for your reply!
Working with shell-scripts is a really amazing option which I did not considered so far.
Sadly it won't solve my problem cause the sample tool have to be executed before as well...
Old   July 5, 2009, 05:16
xinguang cui
I am sorry that this is the only information I could provide. I don't have any other idea on it.
Good luck!
Old   August 27, 2010, 08:42
Heesei is on a distinguished road
Hey Svens
Did you find out in the meanwhile why the value in the last cell is missing?
I have the same problem now and I don't know what to do to get the values for all cells.
Cheers,
Irina
Heesei is offline   Reply With Quote
Old   September 2, 2010, 11:13
And
Andrea Aprovitola
And is on a distinguished road
Hello to the OpenFOAM community.
I'm experiencing a problem when using the sample utility distributed in OpenFOAM 1.6.x.
I would like to draw the streamwise component Ux along the y direction for the pitzDaily3D tutorial in non reacting conditions. The sampleDict has the following entries:
setFormat raw;
sets
internalField
type uniform;
axis y;
start ( 0.01 -0.025 0 );
end ( 0.01 0.025 0 );
nPoints 100;
surfaces ();
fields ( U );
The sample utility seems to work properly when it is invoked:
Create time
Create mesh for time = 0
Time = 0
Time = 0.05
Time = 0.1
Time = 0.15
Time = 0.2
Time = 0.25
Time = 0.3
Time = 0.35
Time = 0.4
Time = 0.45
anyway the files internalField.xy created in the "/sets/[0-0.45]" folders a
I tried also to compute the single velocity component by selecting in the keyword fields:
fields ( U.component(0) )
but the result is the same. Does anyone can help me to fix this problem ?
Regards
Andrea
And is offline   Reply With Quote
Sample utility problems msrinath80 OpenFOAM Running, Solving & CFD 12 December 21, 2012 05:51
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Sample has problems with baffles propably problem with particletrackToFace mattijs OpenFOAM Bugs 1 October 22, 2007 09:20
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
need sample post CFD data sets Joe Conti Main CFD Forum 0 April 17, 2000 15:38
