Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
read user input value for post-processing utility
Old   May 31, 2010, 20:37
Default read user's input for post-processing utility
Pascal
Pascal_doran is on a distinguished road
Hi all,
I've been able to read input value for a pre-processing utility:
int main(int argc, char *argv[])
  argList::validArgs.append("value_h");
  argList::validArgs.append("value_b");
  argList::validArgs.append("value_r_c");
  argList::validArgs.append("value_alpha");
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
  const scalar h(readScalar(IStringStream(args.args()[1])()));
  const scalar b(readScalar(IStringStream(args.args()[2])()));
  const scalar r_c(readScalar(IStringStream(args.args()[3])()));
  const scalar alpha(readScalar(IStringStream(args.args()[4])()));
return(0);
but when I do the same thing for a post-processing utility named 'trace_max_vor_droite' (based on 'vorticity' utility) it doesn't work.
Here's what I tried:
void Foam::calc(int argc, char *argv[], const Time& runTime, const fvMesh& mesh)  // Line 41
    argList::validArgs.append("valeur Z");
    const scalar coord_z(readScalar(IStringStream(args.args()[1])()));
The error message:
SOURCE=trace_max_vor_droite.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/postProcessing/postCalc -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/trace_max_vor_droite.o
trace_max_vor_droite.C:41: error: ‘void Foam::calc(int, char**, const Foam::argList&, const Foam::Time&, const Foam::fvMesh&)’ should have been declared inside ‘Foam’
make: *** [Make/linux64GccDPOpt/trace_max_vor_droite.o] Error 1
I'm very interested to learn how OpenFOAM works! Help would be very appreciated
Thank you,
Pascal
Pascal_doran is offline   Reply With Quote
Old   June 3, 2010, 17:41
Pascal
Somebody has suggestions?
Pascal
Old   June 11, 2010, 12:03
Pascal Doran
Newtein is on a distinguished road
Ideas/suggestions would be greatly appreciate
thank you
Newtein is offline   Reply With Quote
input value, utility
Incorrect utility names in User Guide schoon OpenFOAM Bugs 1 October 23, 2008 11:32
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
time dependent velocity input by user subroutine shohel mahmud Siemens 4 December 18, 2007 11:40
Ist it only me that cant read the user guide pdf olle53 OpenFOAM 5 April 5, 2006 22:14
Transient user input table Bart Siemens 0 January 10, 2005 01:27
