Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
interpreting velocity field
Like Tree2Likes
  • 2 Post By santiagomarquezd
Old   October 8, 2010, 01:23
Default interpreting velocity field
Abhinav Sharma
asharma is on a distinguished road
I've recently started using Openfoam, i'm planning to club my flow field results with Lagrangian particle dispersion model that i have coded. I'm having trouble interpreting the velocity data, for example in the example "cavity" run with RAS, for time step 20 we get a listing of 400 velocity data points. I understand my mesh is 20*20*1 grid , and velocities are calculated at volume centers. What co-ordinates do the results pertain to, or other wise is it possible to get velocity field in terms of exact gird location in my mesh.
Hope i'm clear with what i'm trying to get at...
thanks in advance!
abhinav
asharma is offline   Reply With Quote
Old   October 8, 2010, 20:21
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Abhinav, values are calculated at cell centres, but this info is not stored in /constant/polyMesh structure, so to obtain the coordinates of points which solution belongs to you have the command,
writeCellCentres
this command will give you three files in /0
ccx
ccy
ccz
they have the x, y and z coordinates of cell centres for internal mesh and face centres for boundary mesh.
Regards.
beeo and liyijun like this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   October 9, 2010, 01:19
Abhinav Sharma
Thank you so much Santiago, ill be back with more queries soon!...
regards,
Abhinav
velocity profile
real velocity field from energy spectrum Angel Main CFD Forum 7 December 13, 2013 20:40
how to make velocity field constant with time openfoam1 OpenFOAM 0 February 1, 2010 15:53
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 18, 2009 23:24
Reconstruction of velocity and pressure field Jianglan Main CFD Forum 0 October 6, 2008 00:04
Turbulence Production Based on the Curl of the Velocity Field ngj OpenFOAM Running, Solving & CFD 0 April 4, 2008 05:22
