January 12, 2011, 06:16 |
Weird artifacts in ParaFoam
John Wang
Rep Power: 17 |
Hi guys,
I've recently been seeing these weird artifacts when post-processing using ParaFoam when viewing slices: I have not seen anything like this before in OF1.6, and haven't noticed this in OF1.7 until now (since I haven't been using the slice function before this). Any idea on how to fix this problem? Thanks. My system is OpenSUSE 11.3 with ATI graphic card, if that helps. John |
January 13, 2011, 00:47 |
John Wang
Rep Power: 17 |
Well, after some investigation it appears that the ATI driver is at fault. The flow field rendered correctly when using mesa driver through SSH.
John |
January 13, 2011, 18:00 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi John,
Well, you got lucky that you only got artifacts. Some people aren't so lucky and get complete crashes of their machines, because the OpenGL driver (from the closed source ATI/NVidia/Intel drivers) put its finger in the wrong bits of memory, or GPU instructions, in the graphics card. You can try downgrading your ATI drivers to a previous version or upgrading to the most recent version. The other possibility is that you have enabled the nifty and sweet hardware acceleration for desktop display; you may loose eye candy when working on the desktop, but then it might be less likely that some application will crash due to it. Best regards, Bruno
Display Modes | |
[OpenFOAM] Weird Problem with ParaFoam via SSH | cwang5 | ParaView | 2 | July 19, 2010 09:00 |
[OpenFOAM] pointVectorField in ParaFoam | s_braendli | ParaView | 0 | April 22, 2010 08:36 |
[OpenFOAM] Segmentation fault with paraFoam and paraview 3.6.1 on Fedora 11 32 and 64 bit | nanes | ParaView | 2 | September 11, 2009 09:12 |
[OpenFOAM] Parafoam basic questions | qtian | ParaView | 0 | July 20, 2007 11:52 |
[OpenFOAM] ParaFoam OF 14 decomposed cases | philippose | ParaView | 4 | April 18, 2007 05:17 |
