Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Output force distribution for each face on a patch
Old   October 19, 2011, 11:21
Default Output force distribution for each face on a patch
meh
Matt
meh is on a distinguished road
Hello.
I'm really sorry if this question has already been asked, I couldn't locate the solution in the forums.
I can output the integrated pressure and viscous forces on a patch using libforces.so. I've also managed to output pressures and stresses per face using the sample function.
What I need is the forces per face on a patch, together with the coordinates and area of each face. I'll be using this to input to a fluid structure interaction model.
Can anyone advise how to output the distribution of forces on a patch, rather than just the integrated value?
Thanks very much for your time
Matt
meh is offline   Reply With Quote
Old   October 20, 2011, 09:25
David Boger
boger is on a distinguished road
I'm not sure I understand. If you're able to output the pressure and viscous stress per face, then don't you just need to multiply by the face area?
David A. Boger
boger is offline   Reply With Quote
Old   October 20, 2011, 09:27
meh
Matt
Hi David
Thanks very much for your reply. Using sample i've only managed to output a vtk file, which doesn't have face areas in it. Can I output face area using sample?
Thanks very much
Matt
Old   October 20, 2011, 09:37
David Boger
Ah - now I understand, but I don't know the answer. I assumed you were modifying a utility like patchIntegrate or wallShearStress, in which case you should be able to modify the utility slightly to write out what you need. Someone else probably has a more elegant solution.
David A. Boger
Old   October 20, 2011, 11:07
meh
Matt
I'll have a look at these utilities, thanks. If there any other ideas out there I'd be glad to hear them.
distribution, force, openfoam, patch
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 03:28
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
[mesh manipulation] Using createPatch in place of couplePatches sripplinger OpenFOAM Meshing & Mesh Conversion 8 November 13, 2009 07:14
