September 27, 2011, 04:45 |
LTSinterfoam visualization
pere
Rep Power: 15 |
I'm playing with wigley hull tutorial with OpenFOAM-2.0.x, that I solved with LTSinterfoam, and when I visualize the results with paraView 3.8.1 I don't know how to see the waves height. Anyone knows how to do it? |
September 27, 2011, 22:26 |
Roman Thiele
Rep Power: 20 |
you could try to just view by
- using isosurface using value 0.5 - cutting the block along the hull and showing only alpha - showing alpha as a volume field (the dropdown menu where you chose surface, or surface with edges, etc..)
~roman |
September 28, 2011, 04:19 |
pere
Rep Power: 15 |
thanks romant
October 14, 2011, 13:02 |
Rep Power: 15 |
I've got an embarassingly newbish question:
What file(s) do I open to view the Wigley hull results? EDIT: nvm, I'm having an unrelated issue with my paraFoam install. Last edited by CThib; October 14, 2011 at 13:53. |
October 14, 2011, 15:25 |
Rep Power: 15 |
I fixed my paraFoam install. Romant, what exactly did you mean by using isoCurve with value 0.5? I'm viewing it with alpha as a volume field, and I can tell that there are pressure distributions when I create a slice but they are very difficult to see. I noticed the LTSInterFoam tutorial states that things were changed to show the wave elevations. That makes me wonder, is it even possible to see real waves with the default values? Thanks
Display Modes | |
Visualization of higher order solution | shyamdsundar | Main CFD Forum | 1 | July 23, 2010 03:55 |
Visualization Software for CFD | Paul | Main CFD Forum | 3 | March 25, 2006 17:16 |
help: flow visualization library | soofuu | Main CFD Forum | 3 | September 28, 2000 10:54 |
CFX4-Interface for OpenDX Visualization Software? | Doris Rieger | Main CFD Forum | 0 | December 1, 1999 06:41 |
Flow Visualization of impinging swirling flow on the wall. | sangaria | Main CFD Forum | 2 | March 26, 1999 13:31 |
