March 18, 2012, 08:59 |
foamToVTK: load all the parts at once
Hi all;
if you run foamToVTK it creates a different folder for every .stl you got. That means that if you then want to load all of the parts composing your geometry, you need to load every each one of them separately since they are in different folders… Is there any way to load all of them at once? Thank you! |
[OpenFOAM] How to load all <case>/surfaces/*/*.vtk at once into Paraview | holodeck10 | ParaView | 8 | November 22, 2019 17:52 |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 15:18 |
icem hexa - load different blockings for each part of geometry??? | Catthan | ANSYS Meshing & Geometry | 2 | May 28, 2010 11:27 |
[snappyHexMesh] SnappyHexMesh complex geometries amp thin wall parts | hsieh | OpenFOAM Meshing & Mesh Conversion | 0 | September 22, 2008 17:34 |
Using load vector for parallel partitioning | Kevala | FLUENT | 0 | May 1, 2001 12:11 |
