internal field
Like Tree7Likes
  • 1 Post By Phicau
  • 1 Post By Phicau
  • 4 Post By Phicau
  • 1 Post By libia87
Old   April 26, 2012, 05:56
Default internal field
anonymous
libia87 is on a distinguished road
Hi!
I have a cylinder and I want to simulate the concentration.
my problem is: I have the cylinder split in 20 parts and I want to say that 10 volums are C=0.5 and the others 10 volums C=-0.5.
how can I put this in the /0?? becouse in internalField can only be one value ... and I want to specify the volums, not the surfaces
Thanks!
libia87 is offline   Reply With Quote
Old   April 26, 2012, 06:04
Pablo Higuera
Phicau is on a distinguished road
You can use setFields for that purpose. Check the damBreak tutorial for an example.
Regards
Phicau is offline   Reply With Quote
Old   April 26, 2012, 06:36
anonymous
Regards
ok!!! thanks
i have another question, in the example of break damm
defaultFieldValues
volScalarFieldValue alpha1 0
regions
boxToCell
box (0 0 -1) (0.1461 0.292 1);
fieldValues
volScalarFieldValue alpha1 1
what is box (0 0 -1) (0.1461 0.292 1);?? I know that the second parentesis is the coordinates x,y,z , but (0 0 -1) i don't know what it is.
and in my case that i have a cylinder, how can I describe the coordinates if it's cylindrical??
thanks
Old   April 26, 2012, 07:49
Yogesh Bapat
ybapat is on a distinguished road
For cylinderical region you need to use cylinderToCell.
ybapat is offline   Reply With Quote
Old   April 26, 2012, 09:39
Pablo Higuera
All the cells whose center is within a box with lower corner (minX minY minZ) = (0 0 -1) and upper corner (maxX maxY maxZ) = (0.1461 0.292 1) get the alpha1 = 1.
Depending on the geometry of the 20 parts you may need to use cylinderToCell as Yogesh says, or you can continue using boxToCell.
vsammartano likes this.
Old   April 27, 2012, 03:08
anonymous
ok thanks! but in the cylinder the lower corner and de upper corner which numbers I have to put??
the cylinder is split in 20 similar parts, like 20 small cylinders
Old   April 27, 2012, 03:19
Pablo Higuera
cylinderToCell has a different input, 2 points and a radius instead of a box:
p1 (0 -0.08 0);
p2 (0 0.06 0);
radius 0.12;
libia87 likes this.
Old   April 27, 2012, 03:21
anonymous
defaultFieldValues
volScalarFieldValue p 0
regions
cylinderToCell
cylinder (0 0 0) (0 0 2.5) 1.25;
fieldValues
volScalarFieldValue p 1
with this setFields give me an error, FOAM FATAL IO ERROR: keyword p1 is undefined in dictionary cylinderToCell
what does it mean?
Old   April 27, 2012, 03:24
Pablo Higuera
It asks for word p1, as you have not specified the points:
defaultFieldValues
regions
cylinderToCell
p1 (0 0 0);
p2 (0 0 2.5);
radius 1.25;
fieldValues
libia87, shash, jiaojiao and 1 others like this.
Old   April 27, 2012, 03:27
anonymous
Originally Posted by phicau View Post
it asks for word p1, as you have not specified the points:
Defaultfieldvalues
volscalarfieldvalue p 0
regions
cylindertocell
p1 (0 0 0);
p2 (0 0 2.5);
radius 1.25;
fieldvalues
volscalarfieldvalue p 1
thanks!!!!!
ebtedaei likes this.
Old   May 18, 2012, 10:18
Andrea Cristina
AC87 is on a distinguished road
Hi
i have this error with the tool cylinderToCell
--> FOAM FATAL IO ERROR:
keyword fieldValues is undefined in dictionary "::cylinderToCell"
Can you help me?
AC87 is offline   Reply With Quote
Old   February 4, 2015, 03:20
Warning
range_rover is on a distinguished road
Hi
Can you help me?
check out the spelling of of fieldvalues then
range_rover is offline   Reply With Quote
Old   March 11, 2016, 12:12
Alpha Beta
xoitx is on a distinguished road
HI
I get this message after pasting your code to setfeildsdict
Setting field default values
--> FOAM Warning :
From function void setCellFieldType(const fvMesh& mesh, const labelList& selectedCells,Istream& fieldValueStream)
in file setFields.C at line 124
Field p not found
Setting field region values
Adding cells with centre within cylinder, with p1 = (0 0 -0.003), p2 = (0 0 0.003) and radius = 0.003
--> FOAM Warning :
Field p not found (I'm guessing this has to do with p file.. but I have p_rgh??? :O)
End
Can you help please?
xoitx is offline   Reply With Quote
Old   March 31, 2016, 10:57
martel is on a distinguished road
Originally Posted by xoitx View Post
HI
--> FOAM Warning :
Field p not found
--> FOAM Warning :
End
Hi Xoitx,
I have the same problem!, Did you find a solution?
Regards,
--Carlos
martel is offline   Reply With Quote
Old   March 31, 2016, 11:49
Alpha Beta
Hi Carlos
I solved it using this
// Cells underneath plane such that volume is reached. E.g. for use
// // in setFields to set the level given a wanted volume.
// source targetVolumeToCell;
// sourceInfo
// volume 2e-05;
// normal (0 1 0); // usually in direction of gravity//This is the vector (normal) of the plane
you can find all of the commands and usage here:
openfoam30/applications/utilities/mesh/manipulation/topoSet/
There is a file called topoSetDict
Check it out
Regards
Xoitx
Old   March 31, 2016, 11:53
Hi Carlos
Check it out
Regards
Xoitx
Thanks!
--Carlos
Old   November 11, 2016, 04:44
ali
ebtedaei is on a distinguished road
defaultFieldValues
regions
cylinderToCell
p1 (0 0 0);
p2 (0 0 2.5);
radius 1.25;
fieldValues
Hi, I also same error! :
" keyword p1 is undefined in dictionary cylinderToCell "
I introduced keyword p1 !!!
defaultFieldValues
volScalarFieldValue alpha.water 1
regions
cylinderToCell
cylinder
p1 (-0.83261 0.11118 0);
p2 (0.82468 -0.11012 0);
radius 0.03;
fieldValues
volScalarFieldValue alpha.water 0
Please help me.
Ali
ebtedaei is offline   Reply With Quote
Old   November 11, 2016, 04:46
ali
Originally Posted by libia87 View Post
thanks!!!!!
Hi, I also have same error! :
I introduced keyword p1 :
defaultFieldValues
regions
cylinderToCell
cylinder
radius 0.03;
fieldValues
Please help me.
Ali
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
internal Field BC T.D. OpenFOAM 5 March 14, 2011 04:48
[OpenFOAM] Display internal field together with boundaries gunnar ParaView 4 June 25, 2009 12:00
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
