April 27, 2012, 03:22 |
Pressure BC for solidDisplacementFoam
Tom Schmitz
Rep Power: 15 |
I would like to use a pressure as a boundary condition with SolidDisplacementFoam and I am therefore looking for information about the tractionDisplacement type: type tractionDisplacement; traction uniform ( 0 0 0 ); pressure uniform 0; value uniform (0 0 0); - can the pressure at the surface be directly set in the "pressure" entry without specifiying anything else in the other entries? - what does the entry "value" correspond to? Is it related to the entry "pressure" or the entry "traction"? - is there another type more appropriate to set a pressure instead of a traction? Thanks in advance |
pressure bc, soliddisplacmentfoam, tractiondisplacement |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Using pressure outlet BC | Shreyansh | FLUENT | 0 | November 5, 2010 14:57 |
Help ASAP! pressure inlet & outlet | engahmed | FLUENT | 0 | June 13, 2010 15:33 |
Setting pressure and velocity in inlet | Asghari | FLUENT | 5 | September 22, 2006 13:23 |
