1D turbulence test case
Like Tree1Likes
  • 1 Post By luka86pt
Old   May 23, 2012, 06:09
Default 1D turbulence test case
Luca M.
luka86pt is on a distinguished road
Hello everyone,
I'm doing uncertainty quantification and I need to run 1D test case simulations.
I'd like to know if openFoam is a good solver for a 1D channel flow turbulence k-epsilon model solution.
I'm supposed to use fluent, but it doesn't have monodimensional solution right?
Is there a better software for monodimensional simulations, or do you think that the best thing would be to write a solver?
Thanks in advance,
Luca
luka86pt is offline   Reply With Quote
Old   June 14, 2012, 05:02
Luca M.
I'm sorry, I'll try to explain.
I'm running a turbulent channel flow test case on Fluent but Fluent doesn't accept 1D domain and I need to add 3 knots in the streamwise direction and to set a periodic condition, so at the end I get 3xnumber of 1D elements. Does Openfoam or other solvers allow you to set a 1D domain for this case (I need k-eps standard model as Fluent)?
I'm running about 2000 simulations so it would be really less expensive! So maybe if I don't find anything I should write a solver?! But I don't have enough experience to do it fast =P
Is it clear now? Thanks in advance!
wenxu likes this.
Old   June 14, 2012, 09:00
Retired Super Moderator
Bruno Santos
Greetings Luca,
It's a bit ironic, because if it were not for the spammer, I wouldn't even had noticed your thread.
Additionally, it's good that you've detailed more your question. Hopefully someone will be able to answer you.
Best regards,
Bruno
Old   April 9, 2015, 06:24
pycckuu is on a distinguished road
Originally Posted by luka86pt View Post
Hello everyone,
I need to run 1D test case simulations... k-epsilon model solution.
Luca
I am also interested, there is a possibility to make 1d simulations using special case of 3d and symmetric around axis case.
pycckuu is offline   Reply With Quote
Old   November 6, 2016, 04:36
Freedom
wenxu is on a distinguished road
Anyone has experience with the 1D simulation with OF?
wenxu is offline   Reply With Quote
Old   November 7, 2016, 03:52
Olivier
olivierG is on a distinguished road
hello,
Yes, you can do 1D: just use empty BC for front, back and side, and just set BC on bottom/top. Work well for me.
But turbulence k-e simulation on 1D seem .. original !
regards,
Olivier
olivierG is offline   Reply With Quote
Old   November 7, 2016, 04:25
Freedom
Originally Posted by olivierG View Post
hello,
regards,
Olivier
Thank you for your information!
In your case, it is the non-reacting fluid flow or reacting one? I do not know whether the 1D flame can be simulated by OF.
Best regards,
Xu
Old   November 7, 2016, 04:27
Olivier
hello,
In my case it was a plasma simulation, so similar to a reacting solver.
regards,
Olivier
Old   November 7, 2016, 04:29
Freedom
Thanks, I should have a try!
Old   May 20, 2019, 06:38
arya123xyz
arya123xyz is on a distinguished road
Sir, can you post the test case you tried in OF ?
arya123xyz is offline   Reply With Quote
channel flow, test cases, turbulence model
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 06:35
How to find standard store-seperation test case? peter.zhao Main CFD Forum 6 March 6, 2015 11:31
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
Test Case: Laminar Flow Between Rotating Concentric Cylinders ebertmp OpenFOAM 4 December 3, 2012 11:54
Help Required With Simple Test Case steph79 OpenFOAM Pre-Processing 4 August 3, 2010 07:45
