Setting a Default divSchemes scheme fails
Old   August 1, 2012, 17:52
Default Setting a Default divSchemes scheme fails
Edward Leonard
iamed18 is on a distinguished road
I've noticed that I'm only using "Gauss upwind" in my fvSchemes::divSchemes dictionary, so instead of listing all the exact operations, I figured I would just change the default like so:
divSchemes
       default Gauss upwind;
However, I get this error at runtime:
Starting time loop
Time = 1
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/leonard/OpenFOAM/sgr/testing/makeCase.20120801.174158/system/fvSchemes::divSchemes::default at line 4.
    From function ITstream::read(token&)
    in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
Any thoughts on how to fix this?
iamed18 is offline   Reply With Quote
Old   August 2, 2012, 15:31
Retired Super Moderator
Bruno Santos
Hi Edward,
I saw that you got an answer in your bug report: http://www.openfoam.org/mantisbt/view.php?id=611
Best regards,
Bruno
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 21:20
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 02:41
Godunov scheme Peter Main CFD Forum 6 November 27, 2009 10:51
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
