December 6, 2012, 05:34 |
Boundary Conditions on a Sphere
VS
Rep Power: 13 |
Pals,
i want to apply a BC for velocity on a sphere. I want the velocity ALWAYS to be tangent on the faces of the sphere and never,during the solution, going through its surface. Does anybody know which BC i should apply? |
December 7, 2012, 03:42 |
Hello VSass,
It depends whether your sphere should be moving (movingMesh) or if it is only rotating in a stationary point. I am assuming it is the latter, in that case you can use: rotatingWallVelocity If it is the former: movingWallVelocity Depending on the choice you may need to set some other parameters that describe the motion. Regards, Tom |
December 7, 2012, 03:47 |
VS
Rep Power: 13 |
Thanks Tomf,
i have a fixed sphere so i guess i sould work with the rotatingWallVelocity. Good day to you |
December 7, 2012, 06:44 |
Bernhard
Rep Power: 21 |
I am not sure what you are trying to model, but you could also consider slip as boundary condition.
December 7, 2012, 09:46 |
VS
Rep Power: 13 |
Bernhard,
i have a hybrid sphere seperated in two boundaries, upstream and downstream, and this hybrid sphere is located inside a farfield which is also spherical and we suppose it is far away from our hybrid sphere. I am trying to solve the Navier - Stokes equations in the hybrid sphere using icoFoam,but Courant number keeps crashing no matter what time step i apply. I now work on modified icoFoam in order to keep e.g. maxCo=0.7,but i want to be sure that the crash is not due to boundary conditions. |
boundary conditions, pre-processing |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
