inlet pressure is higher than outlet pressure for fan |
November 14, 2012, 12:22 |
Dear Foamers,
I am running simulation using MRFSimpleFoam solver, the simulation has been done. But now i am comparing the results with experimental result. the simulation result shows that inlet pressure is higher than outlet pressure. I am not able to figure out the mistake in my case. I have attached the U and P file for your consideration, please have a look and help to get it solved. Thanks for your time and help, Sivakumar |
November 16, 2012, 10:15 |
maddalena
Rep Power: 23 |
some observations: 1) before asking help, this is a must-read thread: http://www.cfd-online.com/Forums/ope...-get-help.html 2) your solver is incompressible, thus a uniform 0 value should be used. Relative pressure matters. 3) Is your U defined in agreement with the coordinate system? i.e. should the flow go in positive X direction? mad |
November 16, 2012, 11:36 |
Hi Maddalena,
Thanks for the link, I am using MRFSimpleFoam, Its a passage of axial flow fan, I have defined velocity in x direction (i am not sure about this condition , how good it is) I hope the defined pressure is fine. other boundary conditions are good I think. the convergence not going beyond 0.001. I have attached the figure, please have a look. I have tried different schemes still the residual plot is same. I have attached P and U, please have a look. if you dont mind please give me you email id I will send my case for your consideration. Thank you for your help and time, Sivakumar |
May 17, 2013, 12:14 |
Dogan
hi,
i have the same problem. I am running a centrifugal pump simulation with MRFSimpleFoam. i checked my BC's, but i couldn't find the problem. it supposed to be low pressure in the inlet (suction), and high pressure in the outlet, but the results are showing the opposite. here is the U: dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 1.485); boundaryField { Wall_0 { type fixedValue; value uniform (0 0 0); } Dummy_4 { type cyclicGgi; //inletValue $internalField; value $internalField; } Inlet_7 { type fixedValue; value uniform (0 0 1.485); } Wall_8 { type fixedValue; value uniform (0 0 0); } Dummy_10 { type cyclicGgi; value $internalField; } Dummy_11 { type cyclicGgi; value $internalField; } Dummy_12 { type cyclicGgi; value $internalField; } Dummy_13 { type cyclicGgi; value $internalField; } Dummy_14 { type cyclicGgi; value $internalField; } Dummy_15 { type cyclicGgi; value $internalField; } Dummy_16 { type cyclicGgi; value $internalField; } Dummy_17 { type cyclicGgi; value $internalField; } Dummy_18 { type cyclicGgi; value $internalField; } Dummy_19 { type cyclicGgi; value $internalField; } Dummy_20 { type cyclicGgi; value $internalField; } Dummy_21 { type cyclicGgi; value $internalField; } Dummy_24 { type cyclicGgi; value $internalField; } Dummy_25 { type cyclicGgi; value $internalField; } Dummy_26 { type cyclicGgi; value $internalField; } Dummy_27 { type cyclicGgi; value $internalField; } Wall_30 { type fixedValue; value uniform (0 0 0); } Inlet_31 { type fixedValue; value uniform (0 0 1.485); } Wall_32 { type fixedValue; value uniform (0 0 0); } Dummy_38 { type cyclicGgi; value $internalField; } Wall_39 { type fixedValue; value uniform (0 0 0); } Wall_48 { type fixedValue; value uniform (0 0 0); } Outlet_61 { type zeroGradient; } Dummy_GGI_1 { type cyclicGgi; value $internalField; } Dummy_GGI_2 { type cyclicGgi; value $internalField; } Interface_22_23 { type cyclicGgi; value $internalField; } Interface_28_29 { type cyclicGgi; value $internalField; } Interface_36_37 { type cyclicGgi; value $internalField; } Interface_40_41 { type cyclicGgi; value $internalField; } Dummy_2_6_9 { type cyclicGgi; value $internalField; } Dummy_33_34_35 { type cyclicGgi; value $internalField; } and the p: dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { Wall_0 { type zeroGradient; } Dummy_4 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_10 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_11 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_12 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_13 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_14 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_15 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_16 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_17 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_18 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_19 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_20 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_21 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_24 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_25 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_26 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_27 { type cyclicGgi; //inletValue $internalField; value $internalField; } Wall_30 { type zeroGradient; } Inlet_31 { type zeroGradient; } Wall_32 { type zeroGradient; } Dummy_38 { type cyclicGgi; //inletValue $internalField; value $internalField; } Wall_39 { type zeroGradient; } Wall_48 { type zeroGradient; } Outlet_61 { type fixedValue; value $internalField; } Dummy_GGI_1 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_GGI_2 { type cyclicGgi; //inletValue $internalField; value $internalField; } Interface_22_23 { type cyclicGgi; value $internalField; } Interface_28_29 { type cyclicGgi; value $internalField; } Interface_36_37 { type cyclicGgi; value $internalField; } Interface_40_41 { type cyclicGgi; value $internalField; } Dummy_2_6_9 { type cyclicGgi; //inletValue $internalField; value $internalField; } Dummy_33_34_35 { type cyclicGgi; //inletValue $internalField; value $internalField; } Inlet_7 { type zeroGradient; } Wall_8 { type zeroGradient; //value $internalField } van you see what the problem is? |
December 9, 2013, 05:55 |
Rep Power: 12 |
Hi everyone,
i experience the same thing when i try to simulate the centrifugal fan. here is my BC for p and U U; Code:
[internalField uniform (0 0 0); boundaryField { "rotor.*" { type fixedValue; value uniform (0 0 0); } "gehaeuse.*" { type fixedValue; value uniform (0 0 0) ; } ebene { type fixedValue; value uniform (0 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } inlet { type flowRateInletVelocity; volumetricFlowRate $flowRate; value uniform $inletFlow; } rohr { type fixedValue; value uniform (0 0 0); } "interface.*" { type cyclicAMI; value $internalField; } } Code:
boundaryField { "rotor.*" { type zeroGradient; } "gehaeuse.*" { type zeroGradient; } ebene { type zeroGradient; } inlet { type zeroGradient; value uniform 0; } outlet { type fixedMean; meanValue 0; value uniform 0; } rohr { type zeroGradient; } "interface.*" { type cyclicAMI; value $internalField; } } the only thing that seems not right is the pressure in inlet is higher than that of outlet. anyone can help me? thank you. regards, nash |
December 9, 2013, 08:30 |
Hi There,
Check your stagger angle, how is your torque, is it fine? if you get less pressure raise and more torque, then there could be a problem with root stagger angle. Thanks, Sivakumar |
December 9, 2013, 08:35 |
#7 | |
Rep Power: 12 |
how can i check the stagger angle as well as torque? thank you for your help sivakumar regards, nash -btw did you managed to solve the problem of having the higher pressure inlet than that of outlet? |
December 9, 2013, 08:50 |
root stagger angle, you need to check your design properties.
to check the torque, copy and paste the function in your controlDict file functions ( forces { type forces; functionObjectLibs ("libforces.so"); outputControl timeStep; outputInterval 10; patches (fan); // pname p; // Uname U; rhoName rhoInf; log true; rhoInf 1.20; // density of the fluid CofR (0 0 0); } run the simulation again, then check the torque. Thanks, Sivakumar |
December 9, 2013, 09:09 |
Rep Power: 12 |
after running the simulation i got this for the forces output
forces output: forces(pressure,viscous)((-0.00468209 -0.00186217 -0.00295491),(0.00320589 -0.00866709 -0.00189832)) moment(pressure,viscous)((4.12521e-06 -1.51542e-05 -0.000171072),(4.11675e-05 2.99142e-05 0.000155277)) about the stagger angle, i think it is ok since it was constructed from the real fan. |
December 9, 2013, 09:26 |
Check with your experimental torque, I think your torque is zero.
so you need to check your angle. |
December 9, 2013, 09:42 |
#11 |
Rep Power: 12 |
i will check it then.
but in your case, what is the problem that you were facing and how you overcome it? thanks, nash |
December 9, 2013, 12:56 |
#12 |
Rep Power: 12 |
i dont have the data
-nash- Last edited by nash; December 10, 2013 at 06:08. |
December 11, 2013, 08:57 |
#13 |
Rep Power: 12 |
i check my boundary conditions and compare them with the test case from the single channel pump with the mrf.
i cant see any much difference between them. however the pressure i get at inlet is lower than that of at outlet. i have check my mrf dict (fvOption) everything is fine. so anyone can help me how to solve this ? channelPumpCase Code:
FoamFile { version 2.0; format binary; root "/wrk6/mauvinen/wrkOpenFOAM/caseStorage"; case "tubePumpWF"; instance "0"; local ""; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { impellerWall { type fixedValue; value uniform (0 0 0); } inletDuct { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 3.407); } impellerRim { type fixedValue; value uniform (0 0 0); } voluteWall { type fixedValue; value uniform (0 0 0); } outletDuct { type fixedValue; value uniform (0 0 0); } outlet { type zeroGradient; } insideGGI { type ggi; } outsideGGI { type ggi; } } Code:
FoamFile { version 2.0; format binary; root "/wrk6/mauvinen/wrkOpenFOAM/caseStorage"; case "tubePumpWF"; instance "0"; local ""; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 500; boundaryField { impellerWall { type zeroGradient; } inletDuct { type zeroGradient; } inlet { type zeroGradient; } impellerRim { type zeroGradient; } voluteWall { type zeroGradient; } outletDuct { type zeroGradient; } outlet { type fixedValue; value uniform 500; } insideGGI { type ggi; } outsideGGI { type ggi; } } Code:
FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; #include "include/initialConditions_q10_p132_5" internalField uniform 0 ; boundaryField { "rotor.*" { type zeroGradient; } "gehaeuse.*" { type zeroGradient; } ebene { type zeroGradient; } inlet { type zeroGradient; value uniform 0; } outlet { type fixedMean; meanValue 0; value uniform 0; } rohr { type zeroGradient; } "interface.*" { type cyclicAMI; value $internalField; } } Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; #include "include/initialConditions_q10_p132_5" internalField uniform (0 0 0); boundaryField { "rotor.*" { type fixedValue; value uniform (0 0 0); } "gehaeuse.*" { type fixedValue; value uniform (0 0 0) ; } ebene { type fixedValue; value uniform (0 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } inlet { type flowRateInletVelocity; volumetricFlowRate $flowRate; value uniform $inletFlow; } rohr { type fixedValue; value uniform (0 0 0); } "interface.*" { type cyclicAMI; value $internalField; } } |
December 12, 2013, 16:22 |
#14 |
Rep Power: 12 |
hi everyone its me again..
i know no one is replying to my question, but i will keep posting so far i have done a simulation of radial fan with elongated cylinder lenght about 10 times of of the inlet diameter. The outlet is a semi hemisphere. But then i got pressure inlet higher than that of at outlet. So this is totally wrong. Fan should increase the pressure outlet. So my next step is to change the inlet as semi hemsphere and for the outlet i just extend the end of the housing in about 10 times of the outlet (housing) diameter. i will inform you guys about the result tomorrow. 2 variations of BC i will implement are assigning pressure difference between inlet and outlet, and assigning flowrate (maybe at outlet) if anyone has suggestion, please feel free to post here. I hope i can get a good result and share this with others and helping each other. thank you regards, nash |
December 16, 2013, 09:58 |
#15 |
Rep Power: 12 |
just a litte mistake from the mrf Definition in fvOption
in nonRotatingPatches i just actually need to add AMI patches. Any rotating walls should not be added in nonRotatingPatches. my inlet pressure is now lower than that of outlet. hope this would help other fan simulator |
April 24, 2016, 03:35 |
#16 |
Fluidflow
Rep Power: 10 |
Hello
I know this is an old post but I have the same problem. I am simulating a centrifugal fan using Ansys CFX. Based on the results, the inlet pressure is higher than outlet pressure although the difference magnitude is what I expected from the experimental data. I mean, the pressure difference in experimental data is 1000 pa and when I calculate average total pressure difference between outlet and inlet it is -1000 pa. So what's wrong with that? Regards |
December 30, 2017, 14:16 |
#17 |
Aaditya Maharashtra
Rep Power: 8 |
I am doing simulation of axial flow fan using MRFsimplefoam and also gets results like inlet pressure is more than outlet pressure
Boundary Conditions: Pressure Inlet, Velocity Outlet | BigPapi34 | OpenFOAM Running, Solving & CFD | 4 | August 2, 2014 11:39 |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 00:11 |
Help ASAP! pressure inlet & outlet | engahmed | FLUENT | 0 | June 13, 2010 15:33 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
