how to set BC for flow at a sharp open-channel junction?
Old   July 16, 2013, 22:45
Default how to set BC for flow at a sharp open-channel junction?
Chuyen Nguyen
ntchuyen is on a distinguished road
Hi everyone,
I am simulating 3D flow at a sharp open-channel junction. I use the solver interFoam with k-epsilon model. At initial time, I set BC as the figure in attached file.
The result is very strange. It looks like having a strong flow from the wall opposite of tributary channel to push water cross the main channel.
Do you meet this error? Please give me your advise.
Thank you very much.
ntchuyen is offline   Reply With Quote
Old   July 17, 2013, 07:28
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Chuyen,
Welcome to the fórum!
The inlet velocities in the two inlet surfaces are in the same direction (0 0.6 0). The velocities should be in directions normal to the surfaces.
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   July 17, 2013, 09:35
Chuyen Nguyen
Hi Paulo,
Thank you for your reply.
But at the main inlet, the normal direction of surface is x-direction and at the tributary inlet, the normal direction of surface is y-direction. So I set the velocity Um = ( 0.06 0 0 ) (x-direction) at the main inlet, and Ub = ( 0 0.6 0 ) (y-direction) at the tributary inlet (the velocities at two inlets are different). is it wrong?
It's really doing my head in.
Best regard,
Chuyen.
Old   July 18, 2013, 06:57
Chuyen Nguyen
Hi everybody,
I'm sorry for annoying everyone. I just fix my error. It is due to the mistake of gravity direction.
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
Open channel flow motaba Main CFD Forum 4 March 26, 2011 03:22
Flow through a open channel junction Jose Alfredo C Santos Main CFD Forum 1 April 3, 2002 15:24
