Power Law Velocity
Old   March 10, 2013, 01:42
Default Power Law Velocity
starter
sihaqqi is on a distinguished road
Hi everyone
I am a beginner in openFoam. I have a geometry where two pipes are connected at 90degree. Flow is turbulent. I have made my geometry but now I want to have one seventh power law velocity profile set up in my boundary conditions. I have attached my files if anyone experienced can spare a few moments. Pipe diameter is 72.54mm. Mach number is 0.22 and medium is air. Fow enters vertically upwards in +Y and then turn in the bend at +X. Patches are inlet, outlet, upstream, downstream, symmetry.
Following is input of my "epsilon" file
dimensions [ 0 2 -3 0 0 0 0 ];
internalField uniform 1;
boundaryField
inlet
type powerLawVelocity;
n (7 0 0);
y (0 0.7254 0);
maxValue 10;
value uniform (0 0 0);
outlet
type inletOutlet;
inletValue $internalField;
walls
type epsilonWallFunction;
value uniform 0;
symmetry
type inletOutlet;
Input for P
internalField uniform 0;
boundaryField
inlet
n (7 0 0);
y (0 0.7254 0);
maxValue 10;
outlet
type fixedValue;
value uniform 0;
upstream
type wall;
downstream
type wall;
symmetry
type zeroGradient;
sihaqqi is offline   Reply With Quote
Old   March 10, 2013, 02:42
Michiel
michielm is on a distinguished road
could you specify what you want us to answer/what the problem is you are experiencing?
michielm is offline   Reply With Quote
Old   March 10, 2013, 08:56
starter
Dear Michiel
Many thanks for your response. My problem is I want some piping tutorials with power law boundary conditions and the reason behind them. This is what mu Masters by research thesis is about. I want to know how to set up 1/7th power law velocity profile in all k, p, epsilon, u and Nut and NuTilda files so that my system works well. Patches are inlet, outlet, symmetry, upstream, downstream. Do you have any tutorial with some explanation on this type of problem with correct values of n and y. With my values, simpleFoam is giving errors which I do not understand at all.
Regards
Old   March 10, 2013, 09:53
Michiel
I can't find a tutorial in the OpenFOAM tutorials folder (i tried: grep -r -i "powerlawvelocity" *), but you can find an example at the chalmers PhD course on CFD in OF:
Tutorial Power law velocity inlet, InterFoam
EDIT: just an addition, I noticed that the report of the chalmers course uses 1.5-dev so I guess the powerLawVelocity BC is also only available in the -dev versions of OpenFOAM.
1/7th power law, velocity profile
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
plzzz help::energy equation using power law method sepidehkavousi Main CFD Forum 5 April 20, 2012 08:05
Using Power Law Model in Fluent kurne FLUENT 0 October 17, 2011 08:59
power law flow through porous media Francesca Chiusa FLUENT 1 November 3, 2006 14:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
