Allow System Operations in OpenFOAM
Old   March 13, 2013, 19:11
Default Allow System Operations in OpenFOAM
Amir Abbas Aliabadi
amir.a.aliabadi is on a distinguished road
Hello Dear FOAMers,
I like to enable the "allowSystemOperations" in controlDict under opt/openfoam211/etc system directory. This enables to load a shared library using case-supplied C++ code.
To do so, I opened the controlDict with the standard Ubuntu text editor and changed the "allowSystemOperations" setting from 0 to 1, but the editor does not let me modify and save the file with the same name, saying that permission to modification is denied. Is there a way to get around this and overwrite this file?
Many Thanks,
amir.a.aliabadi is offline   Reply With Quote
Old   March 13, 2013, 22:39
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
This is because your install is in /opt, which is outside your home directory and you don't have default permission to adjust things there. if you have administrative rights, you can do
sudo gedit /opt/openfoam211/etc/controlDict
And then change the value you want and save the file. At this point, this is where i say...."I wouldn't use the deb install of OpenFOAM" and urge you to .."compile it from scratch as you will have less problems and learn more about how OpenFOAM works...plus its fun!". Instruction to do so are on the following page. Enjoy and good luck!
chegdan is offline   Reply With Quote
Old   March 13, 2013, 23:24
Amir Abbas Aliabadi
Thank You Chegdan,
Yes, that is a good way to get around this problem.
Cheers,
aaa
Old   January 8, 2014, 21:01
Yesaswi
yesaswi92 is on a distinguished road
Thanks a lot dan.
I initially tried:
sudo nano controlDict
But that kind of messed up the addresses and didn't allow me to mesh for any other case even. Your's was simple and straight forward
yesaswi92 is offline   Reply With Quote
Old   July 1, 2021, 23:17
qutadah
qutadah.r is on a distinguished road
I am running through the same problem when using blockMesh, i checked the contDict file from etc and the "allowSystemOperations" is already set to 1, so i dont know how to fix this problem. thanks!
qutadah.r is offline   Reply With Quote
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 21:07
