April 30, 2015, 00:55 |
i want to make heat exchanger
Kim
Rep Power: 11 |
which there are hot fluid flow in surrounded cold fluid flow.
steady state and incompressible fluid. so I think that I need to fix convection coefficient, (wall conduction coefficient, wall thickness), heat capacity for two species. what is proper solver for me? in openFoam homepage, i can find 'buoyantBoussinesqSimpleFoam' but I don't know how to put heat capacity or convection coefficient because there is not thermodynamic properties file. how can I do? also heat exchange solver give a solution only a species. It means that I have to change solver for two species? or is there another easy way? i need your hint |
April 30, 2015, 12:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: The solvers you're looking for are the ones named chtMultiRegion*Foam. OpenFOAM has a lot of tutorials for it and there is a simplified/incomplete training tutorial provided here: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D
May 7, 2015, 04:56 |
thx bruno
Kim
Rep Power: 11 |
your answer is useful for me, but chtMulti...foam is for compressible fluid but i need incompressible's one so I tried to mix buoyanstB...Simplefoam and that.
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Heat exchanger modelling | Diana | FLUENT | 5 | February 24, 2010 18:02 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
Pressure drop in a heat exchanger | Diana | FLUENT | 5 | December 13, 2007 09:33 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
