sixDOF rigid body boundary condition
Old   May 8, 2013, 08:58
Default sixDOF rigid body boundary condition
achyutan is on a distinguished road
I am using sixDOF rigid body b.c for my fsi solver. I am trying to model elastic solid using spring-dashpot system.
I want to use lift, drag force in the equation of motion defined under sixDOF b.c rather than the total/net force acting on the solid which is used in sixDOF's original code. I found out that sixDOF b.c code is defined under 'Forces' directory inside the source code. so, it should be possible to access the total force on the solid.
can somebody help?
achyutan is offline   Reply With Quote
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 12:02
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
What type of boundary for a moving rigid body? Ryan FLUENT 5 April 13, 2004 11:55
