May 16, 2013, 10:10 |
airfoil in Openfoam-beginer
hamed noordoost
Rep Power: 13 |
hi
I want to compare answer of fluent and Open foam on an Airfoil with laminar, strady flow with constant velocity an Re=2000. I solve the Fluent one But can't Open mesh (same as one use foe fluent) in Open foam. Open foam give me error on attached Picture What is the Problem? |
May 16, 2013, 12:15 |
Nima Samkhaniani
Rep Power: 24 |
dear hamed several suggestions: 1- first try to install a distribution of Linux ( Ubuntu is preferred) if you can not get rid of windows , you can use VMware or virtualbox 2- install OpenFoam on your linux because OpenFOAM in windows is like a pain in the ass However your problem is some where else you used your command wrongly! that command needs that you enter the .msh file name after the command
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
OpenFOAM 1.6.x, 1.7.0 and 1.7.x are not fully prepared to work with gcc-4.5.x | wyldckat | OpenFOAM Bugs | 18 | October 21, 2010 05:51 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
