June 7, 2013, 18:36 |
buoyancy-driven
Rep Power: 13 |
I'm pretty to openFOAM, I would like to know how I can change (increase or reduce) the reynolds number in the buoyancy-driven case tutorial?
Any help on this would be appreciated Thanks much |
June 9, 2013, 02:52 |
Nima Samkhaniani
Rep Power: 24 |
well, you can change your fluid properties or change temperature difference to increase velocity
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
June 9, 2013, 19:58 |
#3 | |
Rep Power: 13 |
not sure about what the problem would be? Thanks, |
June 10, 2013, 01:49 |
Nima Samkhaniani
Rep Power: 24 |
its easy you need just to click on stream traces and choose appropriate line source, if domain disappear, look whether the eye in pipeline browser is active or not
June 11, 2013, 12:16 |
Rep Power: 13 |
Right, I did it and I keep having the same problem? OpenFOAM works with staggered or collocated grids options. I've seen here that all the solvers work with collocated?
June 11, 2013, 12:27 |
Nima Samkhaniani
Rep Power: 24 |
as much as i know it works with collocated solvers
Display Modes | |
Problem with buoyancy driven in enclosure | Asghari_M | FLUENT | 9 | June 12, 2013 01:02 |
Buoyancy Driven Flow | sunilpatil | CFX | 1 | March 19, 2013 05:38 |
3D Buoyancy driven flow in annulus | Aditya | Main CFD Forum | 0 | February 20, 2007 02:21 |
buoyancy driven flow + unsteady | co2 | FLUENT | 4 | May 6, 2004 12:37 |
buoyancy driven flow in steady state in CFX4.3 | raymondyin | CFX | 11 | May 7, 2001 07:15 |
