amount of non-orthogonal correction
hi,
can anyone give me any idea how much non-orthogonal correction i should use for various degree's of mesh non-orthogonality? i.e. does anyone have any rules of thumb which they use, or is there a reference which gives a correlation which is useful? attached is the checkMesh log for my mesh: Code:
Checking geometry... Jonathan |
regarding the nOrthoCorr loops, i am running a steady-state simulation, so as far as i understand it, i dont need to use additional 'corrector' loops in the SIMPLE loop - i think the iterative nature of the steady-state SIMPLE routine takes care of that? Would you be able to comment on that from your experience (i.e. do i understand it correctly)? Also, does non-orthogonal correction (i.e. nOrthoCorr loops) work without setting the laplacian to some form of corrected / limited scheme? i.e. if i just add nOrthoCorr loops but no correction to the laplacian term, am i actually achieving anything?? Many thanks and regards in advance Cheers jonathan |
hi billie,
SIMPLE Code:
// Non-orthogonal pressure corrector loop Quote:
btw, i would be interested to know where snGradSchemes is used explicitly in the code - i thought that the snGradScheme for the laplacian (which is what i am trying to correct) was specified separately in the laplacian dictionary - i.e. Code:
laplacian(nuEff,Urel) Gauss linear corrected; //uncorrected etc cheers jonathan |
