June 27, 2013, 10:59 |
timeVaryingMappedFixedValues and Epsilon
Matt Mosquera
Rep Power: 12 |
Good afternoon,
I am trying to build a model of a chamber with a flow running through it. To start, I created a 2d mesh in Gambit. I have experimental data across the inlet of the channel. I was looking to apply the timeVaryingMappedFixedValues boundary condition to the channel. I created the points file and the corresponding u, k, and epsilon files. The points file has points at the front, middle, and back of the 2d cells. I realized this was because the BC works off of a plane. When I run the simulation, I get a floating point exception error. After a lot of debugging and fiddling with the code I believe I narrowed it down to the epsilon file being the issue. If I change the boundary condition at the inlet to fixedValue the code seems to proceed just fine. What testing or changes can I make to the code to uncover the problem? I'm also open to using another boundary condition that allows me to map my data to the inlet, but I haven't found one. Thanks, Matt |
June 27, 2013, 13:55 |
Matt Mosquera
Rep Power: 12 |
Nevermind, I discovered the problem. I had some bad data imported that was causing the solution to blow up. It's solving now but this issue has been cleared up.
Cheers, Matt |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Calculation of k and epsilon freezes | Nigirim | OpenFOAM Running, Solving & CFD | 1 | November 14, 2012 07:52 |
epsilon and K blowing up. | sivakumar | OpenFOAM Running, Solving & CFD | 1 | October 25, 2012 04:50 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
