Pressure driven flow in vertical pipe
Old   September 3, 2013, 04:00
Default Pressure driven flow in vertical pipe
Hale
Hale is on a distinguished road
Hi to all,
I have a tank connected to a vertical pipe. The tank is full of water and the sides of the tank have the following boundary condition
Inlet
U: zeroGradient;
p: zeroGradient;
alpha1: fixedValue uniform 1;
The water in the tank would then fall into the vertical pipe. The outlet of the pipe has the following boundary condition
outlet
U: zeroGradient;
p: fixedValue uniform -250;
alpha1: zeroGradient;
The upper side of the tank is then open to the atmosphere with following boundary condition
atmosphere
U: inletOutlet;
p: totalPressure (p0=0);
In this way I want the water to fall down based on the pressure difference between outlet and inlet. But with the mentioned boundary conditions the water moves upward and the simulation crashes after some seconds. I guess that the hydrostatic pressure at the outlet causes problems, since there is a positiv hydrostatic pressure corresponding to the water in the pipe.
Am I choosing wrong boundary conditions?
I really appreciate any help and idea.
NB. I'm using interFoam.
Hale is offline   Reply With Quote
Old   September 4, 2013, 13:47
Nima Samkhaniani
nimasam is on a distinguished road
well whats your OpenFOAM version ?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   September 4, 2013, 17:44
Hale
It's version 2.0.1
Old   September 5, 2013, 00:53
Nima Samkhaniani
then you should assign p_rgh not p! p will be calculated then through solving problem whats your p_rgh configurations?
Old   September 5, 2013, 04:15
Hale
Sorry I didn't write that in the discribtion but I am actually assigning p_rgh and not p.
By the way do you know how to change the values for Sp and Su. In the page below, post #7 decribes that the problem with unbounded alpha1 can be solved by changing Sp and Su but I have no idea how and where to change them. Do you know that?
http://www.cfd-online.com/Forums/ope...tml#post449990
Thanks for your time
Old   September 5, 2013, 09:17
Nima Samkhaniani
why do u assign p_rgh a negative value?
well, you should change the source code, look at alphaEqn.H, in
solvers/multiphase/interFoam
and
solvers/multiphase/compressibleInterFoam
then compile your code , however i think atleast now you should get sure about your BC it can be future step
Old   September 13, 2013, 08:16
Hale
Thanks a lot Nima. I have solved the problem.
Application of a pressure gradient/forcing term in a compressible pipe flow mrs206 OpenFOAM 1 July 14, 2017 12:36
total pressure change in a pipe flow Im FLUENT 5 February 23, 2017 08:55
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 06:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
