Cyclic BC and moving mesh
Old   August 6, 2013, 10:39
Default Cyclic BC and moving mesh
siri
snippsnuske is on a distinguished road
Can anyone help with cyclic BC???
I am trying to use cyclic BC on inlet and outlet for a case with dynamic mesh (wind over waves). The mesh does not move/change at the outlet and inlet patch and therefore I thought it could be possible to use cyclic conditions. I am running the case for a short time (I use pimpleDyMFoam) and then I am changing the patches to cyclic (by the use of foamUpgradeCyclic). Not sure if this will work but it looks like the syntax is accepted but I get a more fundamental problem about the pressure? I get this error message and it is related to set a reference cell for p.
Anyone know a “work around”?
--> FOAM FATAL IO ERROR:
Unable to set reference cell for field p
Please supply either pRefCell or pRefPoint
file: /import/br1raid6a1h2/stud/sirik/pimpleDyMFoam.onewave/w2_su_cyclic2/system/fvSolution::PIMPLE from line 70 to line 72.
From function void Foam::setRefCell
const volScalarField&,
const dictionary&,
label& scalar&,
bool
in file cfdTools/general/findRefCell/findRefCell.C at line 115.
FOAM exiting
Siri
snippsnuske is offline   Reply With Quote
Old   August 11, 2013, 05:26
Danesh S
DaSh is on a distinguished road
In your fvSolutions you should find something like:
PIMPLE
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 1000;
pRefValue 0;
Apparently at least your entries for pRefCell and pRefValue are missing.
Regards!
DaSh is offline   Reply With Quote
