Boundary Condition problem with multiphase flow |
August 13, 2013, 11:09 |
Hi there,
Basically, the problem I have is a square domain initially filled with air and as the time goes by, water come in through the inlet. The moisture is then carried to the outlet by a moving wall with a constant velocity. I am using interFoam to solve the problem and when checking out the solution, there is no water coming in. The boundary conditions for the two phases are: air: for the walls is zeroGradient; outlet { type fixedValue; uniform 0; } inlet { type inletOutlet; inletValue uniform 0; value uniform 0; } atmosphere { type inletOutlet; inletValue uniform 1; value uniform 1; } water: for the walls is zeroGradient; outlet { type fixedValue; uniform 0; } inlet { type inletOutlet; inletValue uniform 1; value uniform 1; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } for the pressure field: for the walls is fixedFluxPressure with value uniform 0; outlet { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } inlet { type zeroGradient; } atmosphere { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } for the Velocity file U: walls... fixedValue uniform (0 0 0) outlet { type pressureInletOutletVelocity; value uniform(0 0 0); } inlet { type pressureInletOutletVelocity; value uniform(0 -0.1 0); } } atmosphere { type pressureInletOutletVelocity; value uniform(0 0 0); } I have tried to adapt these condition from the damBreak tutorial since I have no experience by using OpenFOAM but, it is not working. I hope you can help me to find out the solution for this problem. Thank you very much. |
boundary condition, interfoam, multiphase, openfoam |
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
Rotating wall velocity boundary condition for axisymmetric flow problem | diwakaranant | SU2 | 1 | March 23, 2013 23:45 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
Boundary condition for not fully-developed flow | John | FLUENT | 0 | July 15, 2005 07:07 |
