August 31, 2013, 10:25 |
Compressible, buoyant BC for porous flow
Robert
Rep Power: 13 |
I'm trying to set up a case like seen in the following sketch: The solver is chtMultiRegionFoam because I've also implemented a thermalMass zone around the tube. Buoyancy is turned off by setting g to zero. I've tried a lot of things but I always end up with large vortices in the porous zone. Everything worked fine without multi-region in rhoPimpleFoam, so I guess my BC settings are to blame. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101300; boundaryField { Front_Plate { type zeroGradient; } End_Plate { type zeroGradient; } Propene_Inlet { type zeroGradient; } Mid_Cylinder { type zeroGradient; } Inner_Quartz_Tube { type zeroGradient; } Probe_Porous_Outlet { type fixedMean; meanValue 101300; value uniform 101300; } Probe_Walls { type zeroGradient; } Gas_Mixture_Inlet { type zeroGradient; } flowRegion_to_thermalMass { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101300; boundaryField { Front_Plate { type calculated; value uniform 101300; } End_Plate { type calculated; value uniform 101300; } Propene_Inlet { type calculated; value uniform 101300; } Mid_Cylinder { type calculated; value uniform 101300; } Inner_Quartz_Tube { type calculated; value uniform 101300; } Probe_Porous_Outlet { type calculated; value uniform 101300; } Probe_Walls { type calculated; value uniform 101300; } Gas_Mixture_Inlet { type calculated; value uniform 101300; } flowRegion_to_thermalMass { type calculated; value uniform 101300; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { Front_Plate { type fixedValue; value uniform (0 0 0); } End_Plate { type fixedValue; value uniform (0 0 0); } Propene_Inlet { type fixedValue; value uniform (0 0 0); } Mid_Cylinder { type fixedValue; value uniform (0 0 0); } Inner_Quartz_Tube { type fixedValue; value uniform (0 0 0); } Probe_Porous_Outlet { type inletOutlet; value uniform (0 0 0); inletValue uniform ( 0 0 0 ); } Probe_Walls { type fixedValue; value uniform (0 0 0); } Gas_Mixture_Inlet { type uniformFixedValue; uniformValue table ( (0 (0 0 0)) (1 (2.2366 0 0)) ); } flowRegion_to_thermalMass { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 293.15; boundaryField { Front_Plate { type zeroGradient; value uniform 293.15; } End_Plate { type zeroGradient; value uniform 293.15; } Propene_Inlet { type zeroGradient; value uniform 293.15; } Mid_Cylinder { type zeroGradient; value uniform 293.15; } Inner_Quartz_Tube { type zeroGradient; value uniform 293.15; } Probe_Porous_Outlet { type inletOutlet; value uniform 293.15; inletValue $internalField; } Probe_Walls { type zeroGradient; value uniform 293.15; } Gas_Mixture_Inlet { type uniformFixedValue; uniformValue table ( (0 293.15) (1 443.15) ); } flowRegion_to_thermalMass { type compressible::turbulentTemperatureCoupledBaffleMixed; value uniform 293.15; neighbourFieldName T; kappa fluidThermo; kappaName none; } } // ************************************************************************* // Robert Last edited by vainilreb; September 1, 2013 at 05:55. |
Incompressible and compressible flow. | Confused student. | Main CFD Forum | 27 | March 18, 2017 12:25 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Compressible Fluid Flow in COMSOL Multiphysics | BBG | COMSOL | 1 | November 19, 2008 14:05 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 13:19 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 17:23 |
