timeVaryingMappedFixedValue BC
Hi all,
I trying to simulating a simple geometry in 2D, and my boundary conditions are defined pressure in the inlet and outlet and velocity evaluated by this pressure difference. My problem is that I have to grow the difference of pressure very slow, because if I put a big difference of pressure with a initial field of velocity defined as zero, it does not converge. So, what I am doing is to set a small difference of pressure and as the flow is solved I am changing the difference of pressure. Anyway, what I am trying to do to avoid this work setting a "ramp" in the difference of pressure, using the BC timeVaryingMappedFixedValue. The problem is that it is not working. I will put my BC here and I appreciate if you can help me on that! So, my inlet and outlet files are: for velocity: inlet { type pressureInletVelocity; value uniform (0 0 0); } outlet { type zeroGradient; } for pressure: { inlet { type timeVaryingMappedFixedValue; fileName "ramp.dat"; outOfBounds clamp; } outlet { type fixedValue; value uniform 0; My ramp file: ( (0.0, 0.001) (0.1, 0.010) (1.0, 0.100) ) The error message is: -> FOAM FATAL IO ERROR: keyword setAverage is undefined in dictionary "/home/marcelo/Desktop/opt/openfoam221/tutorials/incompressible/icoFoam/Projeto/bockmesh/APISeal2D52/0/p.boundaryField.inlet" file: /home/marcelo/Desktop/opt/openfoam221/tutorials/incompressible/icoFoam/Projeto/bockmesh/APISeal2D52/0/p.boundaryField.inlet from line 25 to line 27. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 402. FOAM exiting Thank you very much, Regards, Marcelo |
Tutorial/material
Do you have any material/tutorial reference about this boundary condition?
timeVaryingMappedFixedValue Thank you very much Regards Marcelo |
Hi Marcelo, I am also facing the same problem. I tried out both timeVaryingMappedFixedValue and timeVaryingUniformFixedvalue but did not worked. Did you figured out how to solve the problem?
Hi Marcelo,
Have you looked at the pitzDailyExptInlet under simpleFoam? Based on the error message that you have, it seems like you have missed out defining the "setAverage" value in the file indicated in the error. Perhaps the tutorial might help you with it? Regards, Antimony |
