December 1, 2013, 04:52 |
Buggy twoPhaseEulerFoam turbulence Model
Rep Power: 12 |
Hello everyone,
I am working on a multiphase Simulation with twoPhaseEulerFoam/compressibleTwoPhaseEulerFoam And have a problem with a buggy turbulence model. My case works fine in buoyantPimpleFoam, but when I try to use wall functions (i.e. epsilonWallFunction) for Epsilon, I always get this message: Code:
--> FOAM FATAL ERROR: request for turbulenceModel turbulenceModel from objectRegistry region0 failed available objects of type turbulenceModel are 0 ( ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/andreas/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 136. FOAM aborting When I replace the boundary conditions with "Dummy" to get shown available BC's, I see a lot possibilities. But only the simple ones like zeroGradient work. It gets even more curious. When I calculate the Epsilon-value with the buoyantPimpleFoam-Case and copy them into the twoPhaseEulerFoam-Case with a 'fixedValue' BC, nothing changes at all. In the solver/twoPhaseEulerFoam dictionary exist even special files called 'kEpsilon.H' or 'wallFunctions.H'. But my case still doesn't work properly. I have to add, I am calculating with kineticEnergy off. I did it because I try to make the dispersed Phase act more like a simple gas. Could this be part of the problem? I am using OF220. Thanks you for your attention or help. Sincerly, Andreas |
December 1, 2013, 09:03 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Andreas,
I had a quick look at the tutorials for twoPhaseEulerFoam and they do not seem to use the conventional turbulence models. In addition, I checked to which libraries the solver links to, by running this command: Code:
ldd $(which twoPhaseEulerFoam) This explains why you're seeing that error message. Problem is: why don't even the tutorials for this solver use the specific turbulence models, but still use the k-epsilon fields? Specially, if we look at the output from this command: Code:
ldd $(which interFoam) Code:
libincompressibleTurbulenceModel.so libcompressibleTurbulenceModel.so libincompressibleRASModels.so Code:
libs ( libincompressibleTurbulenceModel.so libcompressibleTurbulenceModel.so libincompressibleRASModels.so ); But the thing is... why is twoPhaseEulerFoam able to compute the k-epsilon fields without these libraries in the first place? So lets try looking at the source code: https://github.com/OpenFOAM/OpenFOAM...PhaseEulerFoam This feels like really old OpenFOAM code... the turbulence model is coded into the solver directly (have a look at the file "kEpsilon.H"). OK, from what I can figure out: this solver is too specifically coded for certain simulation scenarios. You cannot use the generic case preparation that most of the other solvers can handle, because this solver seems to be very restricted to what it was developed to simulate. I had a quick look at the solver multiphaseEulerFoam and is relies on LES for the turbulence modelling, instead of having it coded directly: https://github.com/OpenFOAM/OpenFOAM...phaseEulerFoam Of course the issue now is: which one is more suitable to your simulation? Best regards, Bruno
December 2, 2013, 07:43 |
I give up and start something else
Rep Power: 12 |
Thanks wyldckat for your advice. I inserted those libraries in the controlDict.
libs ( libincompressibleTurbulenceModel.so libcompressibleTurbulenceModel.so libincompressibleRASModels.so ); I tried a second time bye changing a version of the solver itself bye looking on the buoyantPimpleFoam Solver and inserted the missing library entries in the main file. I inserted in the EEqn.H the missing turbulence part Code:
- fvm::laplacian(turbulence->alphaEff(), he) Code:
+ turbulence->divDevRhoReff(U) Both were missing in the compressibleTwoPhaseEulerFoam But after adding them... i gain still got the same error message. So I can give up now peacefully in trying further implementing the turbulence in this solver. I will start in creating an own solver. http://www.cfd-online.com/Forums/ope...imulation.html |
turbulence model, twophaseeulerfoam, wall function |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 22:43 |
turbulence model for Refrigerator | cicatrix | Main CFD Forum | 0 | October 3, 2012 01:47 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 09:02 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
