heat exchanger with porous media
1 Attachment(s)
hi,
I wand to simulate the heat exchange between a porous zone and air. the hot porous zone should heat up the air. The flow channel can be seen in the picture. How can I define the heat transfer between the porous zone and the air? I want to use the chtMultiRegionSimpleFoam solver. The porous zone is defined in the fvOptions dictionary. But how can I define the heat transfer between air and the porous zone? Attachment 27244 |
Hi, colud you do that? i have one problem similar
I have the same problem!
