CyclicAMI with half cylinder/ Projection of boundaries |
December 10, 2013, 10:34 |
Olli
Hey Foamers,
I want to simulate a rotating fan with the cyclicAMI-boundary. To reduce the effort of calculation I only want to simulate the behavoiur of the fan by using one blade, which runs cyclic through a halfed cylinder-volume. It already worked with a complete cylinder. The simplified geometry is shown in the pic below. When the solver runs a while, the following problem appears: AMI: Creating addressing and weights between 2596 source faces and 2596 target faces AMI: 33 non-overlap faces identified AMI: Patch source weights min/max/average = 0, 1.00075, 0.981667 AMI: Patch target weights min/max/average = 0, 1.00075, 0.980402 The explanation of this problem: The rotating AMI rotates away from AMI which stays at its position and some faces loose their overlapping. My question: Is it possible with OpenFoam to project the cells of the CyclicAmi boundary, which are loosing their overlapping, to the other side of the AMI during the rotation? It would be great if somebody has got a solution for this problem! Regards Olli |
cyclic boundaries, cyclicami, fan blade |
Display Modes | |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
[blockMesh] Problems meshing a half of a cylinder with blockMesh | zfaraday | OpenFOAM Meshing & Mesh Conversion | 2 | December 11, 2013 04:41 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 04:56 |
Reynolds number for flow over half cylinder? | Haroon10 | Main CFD Forum | 0 | April 23, 2009 11:09 |
