conjugate heate transfer: thermophysical properties
Old   January 3, 2014, 00:24
Default conjugate heate transfer: thermophysical properties
Sergey
skuznet is on a distinguished road
Dear FOAMers!
I'm trying to simulate conjugate heat transfer in a simple heat exchanger using chtMultiRegionSimpleFoam. I have a water flowing between heated metallic plates. I was able to set up a case based on examples multiRegionHeater and planeWall2D. In these examples air with perfectGas equation of state is used. When I run it with air, the results look ok, at least qualitatively.
However, I would like to use water instead of air, and perfectGas equation of state can't be used.
I tried to use file thermophysicalProperties from the
/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionLiquidHeater/constant/bottomWater/thermophysicalProperties (which is for transient solver)
instead of the file with air properties, I also changed density limits in the system/fluidDomain/fvSolution.SIMPLE. With this changes I was able to run my case, however the results are not correct. The fluid domain doesn't get heated. The temperature increases only on the boundaries of the fluid domain, inside fluid domain temperature does not change. There is something wrong with my definition of fluid, looks like there is no heat conduction inside fluid.
I wonder if anyone can explain me what do I do if I want to use water instead of air?
Can I use water properties from
/tutorials/heatTransfer/chtMultiRegionFoam/multiRegionLiquidHeater/constant/bottomWater/thermophysicalProperties (which is for transient solver)?
If yes, what else I should change in my case?
It would be great if someone can give me a working example of using chtMultiRegionSimpleFoam with water or any other liquid, not gas.
Thank you!
skuznet is offline   Reply With Quote
Old   May 20, 2015, 11:48
Nkl
Nikola
Nkl is on a distinguished road
Hi! I am experiencing the same problem, did you manage to solve it?
Nkl is offline   Reply With Quote
Old   May 21, 2015, 18:24
Derek Mitchell
derekm is on a distinguished road
you have for the fluid
transport       const;
    thermo          hConst;
    equationOfState rhoConst;
irc water doesnt have constant density when you heat it
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   June 1, 2015, 13:08
Nkl
Nikola
Thank you. However, I don't understand why in this file /tutorials/heatTransfer/chtMultiRegionFoam/multiRegionHeater/constant/bottomWater/thermophysicalProperties the same entries valid for air are used.
Should I use icoPolynomial equation of state? It is the only one suggested in case of operating with a liquid.
Regards
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
conjugate heate transfer: thermophysical properties skuznet OpenFOAM Running, Solving & CFD 0 December 8, 2013 00:43
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 11:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
